D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus |
Audi DVD Changer retrofit
Hey guys, this is a guide for retrofitting a 6 DVD changer to your Audi A8 4H (D4) 2015 facelift on a right hand drive model. I managed to find the DVD changer for a very good price on eBay which made interested in retrofitting this to my vehicle. It is fairly straightforward install. The DVD unit fits in the top section of the glove box where the cubby storage is. The DVD changer can be fitted with or without the TV tuner system. Since I retrofitted the TV, I created the wiring to work along with it. The wiring can be as easy or difficult as you wish to do it but I chose to do the difficult way because I wanted to do the wiring to factory standards which meant the power wire had to be routed to the fuse box at the back of the rear passenger seats. As for the Ground and Diagnosis wiring, I piggy backed them from the main harness of the MMI unit in the middle of the centre console. Parts needed: • Audi 6 DVD changer P/N: 4H0035108F. • 8 pin connector for DVD changer P/N: 3B0972724. • 1m fakra cable. • 1m MOST fibre optic cable. • MOST fibre optic cable splitter. • 8mm & 10mm sockets • Stereo removal keys • Female terminal cable assemblies for the DVD driver connector.(https://www.automotive-connectors.co...m2-yellow.html) • 4.5mm split Corrugated plastic conduit for running the cables into. • 16 gauge wires. I chose white for power, black for ground and purple for diagnosis. Let's get started... Wiring Quite straight forward. For the MOST splitter I needed 2 females and 1 male connector. To strengthen and to protect the fibre optic cables, I placed them in the corrugated plastic conduit. I also prepared the ground and diagnosis cables and placed together in the conduit to tidy up the wiring clutter. The wiring diagram and pin assignment of the DVD changer is below as well. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I forgot to take pictures of the completed power, ground and diagnosis cable. A few pictures of the DVD drive ![]() ![]() ![]() ![]() ![]() Now onto the car Few pictures of the interior ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The task involves removing the glove box, fuse box panels on both sides of the dash, driver side lower panel trim, the MMI control unit in the middle, Passenger side lower A pillar trim panel, Passenger side Lower B pillar, Rear Sill panel trim, Rear lower seat bench, Rear passenger seat backrest and the back panel of the boot to reveal the electronics. Remove the Fuse box panels using a flat bladed trim tool. ![]() ![]() ![]() ![]() ![]() ![]() Now remove the driver side lower panel trim. There are 4 size 8mm bolts to remove then pull the panel forward with some gentle force.. might take a few attempts but it will gradually come off. Disconnect all the wiring for the headlight controls, OBD connector and foot well LED light. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now we remove the glove box. There are two bolts next to the fuse box area, 2 at the bottom and 3 at the front inside of the glove box. After that, with a gentle push, the glove box comes off and disconnect the wiring to pull it out of the car. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() To obtain more working space, go ahead and remove the ventilation duct by removing the torx 25 screw and unplug the temperature sensor, then pull out. ![]() ![]() ![]() ![]() We are now ready to remove the MMI unit. It is very important to cover up the centre console with a thick cloth to prevent scratches to the lovely and glossy buttons! We need to remove a few trims to be able to get to the slots for the removal keys. The cover surround trim and flap needs to be removed by removing one bolt on the driver side then using a flat trim tool, pop them out. There are two bolts to remove to take out the cover flap. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() We can now pull out the MMI unit. Slide in the removal keys on both sides, pull out the unit and disconnect the wirings at the back. ![]() ![]() ![]() ![]() ![]() ![]() Wiring harness set up We now start to install the wiring. Black will tap into the brown ground connection and Purple will tap into the Diagnosis connection. The fakra cable will connect the video from the DVD changer to the MMI control unit. This means that the existing fakra video connection from the TV tuner will need to be routed into the DVD changer itself. This will require some work if you have factory installed TV such as a fakra extension cable from the main wiring to the DVD changer. Remove the brown connector block for the diagnosis connection. We are tapping into the green/violet coloured cable on Pin 7. Piggy back the connection and using some tape, secure the connection then plug the cable back in the connector. Same method for the ground.. we are interested in the brown cable in the main quad lock connector. Then connect and feed in the Fakra splitter to the back of the mmi unit's cage. Reconnect all the wiring, including the video fakra connection which will go to the DVD changer and reinstall the MMI unit in its place. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now we can route the wiring to the DVD changer. I zip tied the loom to the factory wiring. For the power wire, i placed it in a lengthy wiring conduit alongside the video cable from the DVD changer to the TV tuner at the rear which i routed along the main wiring harness on the side of the car. This requires the lower A pillar trim, B Pillar trim and Rear Sill panels to be removed. I will post pictures from ETKA on how to remove those at the very bottom of the guide. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Tapping into the fuse box For this we need to get to the brown fuse block ST6 and create a terminal connection at slot 6. Don't forget to disconnect the battery before unplugging the rear electronics. We need to disconnect most of the ecu's and remove the bracket in order to luck the wiring loom well to the fuse box. Unfortunately I was not able to take pictures of the tedious task due to the location a little deep inside the boot. Removing the rear armrest storage box makes the task much easier..so go ahead and remove it. ![]() ![]() Once the power wiring is done, put everything back together and reconnect battery. If you have VCDS, clear up any fault codes there may be in the ecu's. Component Protection will definitely need to be removed otherwise the uninterrupted playback of the movies will be affected. Here are a few shots of the completed job. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ETKA Removal Guides ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I do hope you find this guide useful and any feedback will appreciated.. Thanks
Previously: 2010 Audi A8 4E Quattro Sport TDI Oyster Grey Currently: 2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey Last edited by neeldub; 5th August 2019 at 09:42 PM. |
Well done.
Thanks for this very impressive guide. I was struggling to find a guide to wire my phone holder in. So last Saturday purchased ETKA and managed to do what I wanted in 20 minutes. All my work was done by lowering the driver side lower panel and the right hand fuse box cover.
Thanks for taking the time to do a great write up with loads of photos - I'm sure it'll not only come in useful for this retrofit, but also for various jobs involving trim removal etc.
Thanks ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Nice write up Neel. Great detail
![]() I've seen Neel's car and handy work in the flesh and it's very impressive. Keep up the good work and I'm sure when more D3 owners move on to D4's this thread will prove to be very useful ![]() |
But Neel needs to finish off with a shot of his best movie on his mmi screen
A8L 3.0 TDI sport executive 2014. Audi A2 1.4 petrol 2002 SOLD. Audi A8L 4.2TDI Silver 2006 Seat Ibiza 1.4tdi Eco 2008 Silver (£0 Tax)sold NO VCDS rely on Neeldub |
Tags |
dvd changer, mmi, retrofit |
