Old 5th December 2018, 05:45 PM
Markiii Markiii is offline
Default 2002 S8 o2 sensor
Chaps,
looking to replace the pre cat o2 sensors as I don't think they have ever been done
I think its these
https://www.autodoc.co.uk/bosch/1149541
anyone confirm 100%?
thanks
Old 5th December 2018, 06:57 PM
Looks like that's a generic 4-wire sensor so you have to splice the connector.
This one is the correct part cross referenced by the original number (077906265J), and is the same price.
Old 6th December 2018, 09:29 AM
cheers MK
Old 16th December 2018, 03:58 PM
well they arrived and look like the correct part but looks like you need the arms of Mr tickle and the hands of a newborn to get to them.
Anyone any tips or links to a guide for this job ?
Old 16th December 2018, 07:14 PM
MJ is no doubt the expert on doing this, but it can be done by mere mortals as well. I did mine a couple of years ago, once I managed to find out where they were. Not sure of the correct procedure, but removed the driver side one from below. The passenger side I got to from above, but that resulted in some blood loss and bruising.
Old 28th December 2018, 06:56 PM
27litres's Avatar
27litres 27litres is offline
Dropping the exhausts is probably the best solution, but it's a bit of a faf I would imagine.
If they're not generating codes, I'd be tempted to leave them. They are only used to check CAT efficiency and don't directly effect fueling in any way.
The fronts are way more important.
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 29th December 2018, 12:43 PM
its the fronts we are talking about no?
Old 29th December 2018, 08:24 PM
27litres's Avatar
Sorry, my mistake!
The descriptions of the job made me think you were doing the rears!
The fronts are quite doable. I did mine with an offset O2 socket from memory, with a couple of socket extensions.
Definately fiddly, but I got to both from above. I think I only removed the engine cover and inlet pipe.
I thought Bosch had stopped making the sensor with the correct plug, for a sensor with a generic plug and a new plug for the harness (seriously, Bosch?).
Michaela would be replacing these quite often, so she should know.
I ended up with NTK sensors on mine.
Marty
Family:
Sold:
1997 Audi A4
Old 4th January 2019, 09:43 PM
Tjalling Tjalling is offline
Would be smart if I replace those aswell when i have my engine out of the car
It sucks that I need 4 of those
A8 d2 W12 swb
