Old 29th August 2019, 10:44 PM
Audi Doody Audi Doody is offline
Default Audi A8 D2 Parking Sensor woes
Hi all,
So my parking sensors started to play up, this could manifest itself by them not working at all, or a long beep being heard.
Got it plugged in for diagnostics, and this identified that it was the beeper inside the car that was broken; all of the actual sensors were ok.
Is this a common fault? Apparently the sensor is located behiind the instrument binnacle, is the sensor on its own, or is it part of something else - in other words, will it be expensive?
Many thanks
Old 30th August 2019, 08:02 AM
Do you mean a faulty control unit? The beeper can really only beep or not beep.
I've had plenty of faulty sensors over the years but never (yet) a faulty controller. The wiring and connectors behind the bumpers can get pretty cruddy and corroded too. I suppose it's possible that there's a short at one of the connectors (or at least a partial short caused by water ingress) causing a misleading diagnosis.
Assuming FL (1999-2003), here's the part numbers and locations:
https://nemigaparts.com/cat_spares/e...8q/257/919250/
Should you need one, used controllers seem to be available on Ebay for around 20-30 quid.
Old 30th August 2019, 01:39 PM
I’d echo Mark’s comments. I’ve had a good number of sensors fail, giving symptoms like yours. Did you get a ‘proper’ VagCom scan or use a ‘generic’ scanner? Not sure where you’re located (you can add that to your profile), but many of us are on the VagCom register on this forum and are happy to provide a scan in exchange for travel costs (and perhaps a beer!).
Replacements, as Mark said, are fairly cheap and pretty easy to replace.
