Old 6th June 2019, 05:47 AM
Green Goblin's Avatar
Green Goblin Green Goblin is offline
Default Well well well. EML & MOT failure rules
I’ve learned something. Something big...
But first, a massive thank you to Delboy for clearing my codes and resetting my EML! Top bloke and you have a seriously gorgeous D3 S8 buddy! I wasn’t jealous at all...
As I previously explained - the lambda sensors were throwing a hissy-fit due to that crazy cat Goran and the crazy cats he had fitted (note: I’m being sarcastic with a hint of humour thrown in). World class HJS 100 cell cats mated to a full custom Hayward & Scott exhaust. It sounds absolutely epic and makes the old girl sound like a full-on NASCAR but caused the EML to illuminate (oh dear, I went all Wesley Snipes in Demolition Man there). “Illuminate...”
Knew about the recent changes to MOT rules regarding the EML so I just prayed it would stay off just long enough to get the old girl through. Journey back home from Delboy’s was fine. Next morning...arghhhhhhhhhh...damn light comes on just before I get to Halfrauds Autocentre
Here’s the interesting (and ironic) part: firstly, yes, the car *did* fail. But not on the EML! It was a split (or loose) CV rubber boot. That’s all. It turns out that it’s only a failure for petrol cars registered from 01 July 2003 onwards and diesel cars 01 July 2008 onwards only! My car is 2001 so the EML is just advisory. And, the emissions were *absolutely spot on*
Phew...and the MOT only cost a tenner
Old 6th June 2019, 06:10 AM
Deluminate
I did not know that about the EML. I always reset mine as I drive in to the test centre as it comes on with every other startup :P
Have you tried O2 sensor spacers? They supposedly help with this sort of thing although I've not tried them myself.
Old 6th June 2019, 06:25 AM
...have you tried O2 sensor spacers? They supposedly help with this sort of thing although I've not tried them myself.
Gonna try this approach next. I keep reading about using spacers for the sensors. A reputable exhaust place should be able to do this.
Old 6th June 2019, 06:52 AM
Any garage should be able to do it really. Its just a case of unscrewing the sensors and putting the spacer between them and the exhaust. Right-angle spacers would be prudent as there's not a lot of room between the top of the sensors and the tunnel / propshaft.
Old 6th June 2019, 02:38 PM
Sorry about all the trouble those crazy cats caused
Glad you passed despite the engine light.
By the way you already have top quality spacers on those rear labmbdas.
So I guess the next step is either get a VCDS cable so you can re-set the light yourself, or pay MRC Tuning to code out the error code. They don't remove the rear lambdas for some reason, I guess it would require a more major re-code because they are looked for during the start-up routine. Maybe they can do that but that may cost more money, then you can ditch those lambdas completely.
You have these ones, Wayne Angle blocks
https://www.audiworld.com/forums/a4-...s-yay-2376477/
You could try spark plug anti-foulers on top of the Wayne blocks to move the lambdas out further?
Name:	Wayne Block.jpg
Old 6th June 2019, 03:29 PM
Markiii Markiii is offline
pair of these might helps
https://www.ebay.co.uk/itm/90-Sensor...item4b612a1860
Old 13th June 2019, 10:04 PM
I wonder what would happen with mine then if the EML was on?
It's a D2, built in April 2002, but was first registered in October 2003...…
