Old 2nd May 2019, 04:06 PM
oldnick oldnick is offline
Default CD stack problem
having cleaned the stack with a CD cleaning disc selecting a disc now gets a CD to play,after about a minute, then stops again , after perhaps 30 seconds
anyone had this?
Old 2nd May 2019, 06:06 PM
No. Plenty of "CD Errors" which usually cleared after removing and re-loading the CD cassette but not something like you have described. Sorry its not much help
Old 3rd May 2019, 09:47 AM
thanks ,not at all
will try what you did , reload and see if it helps
Old 3rd May 2019, 11:55 AM
I've got a spare CD changer somewhere, but I suspect I'm not alone in that.....
Old 6th May 2019, 05:16 PM
there are these stacks fitted to a variety of vehicles
do they all have the same electrical connections?
mine is marked
4DO 055 111B NP245/94
Old 6th May 2019, 05:41 PM
4B0 035 111A here. NP2 (whatever that means) and 11/01 (date code?)
Matsu****a CX-CA1821LH. Din-style round 13-pin socket on the lead.
Old 7th May 2019, 01:42 PM
I "think" a 4D part is for A8/D2 and 4B part is for an A6 of similar vintage. Essentially identical though.
There are later versions that I've seen with a "B" (not A) suffix that seem to have a different connector.
Quite sure mine worked (or used to, been in store for a while) on my S8 as I've swapped them over several times when "playing with" wiring for TV inputs to the RNS-D.
I did connect it very briefly today, but only to eject the CD cartridge and confirm it was empty - I thought I might have left some in at the last swap!
