Old 13th June 2019, 05:44 PM
Markiii Markiii is offline
Default New Ignition Coils
Been planning on changing the plugs for a while, and since its on the orginal coils at 137k I figured I'd do those to,
Any recommendations or ones to avoid?
I assume these should be ok?
https://www.autodoc.co.uk/ngk/7006391
Old 24th June 2019, 11:22 AM
bump
Old 24th June 2019, 11:04 PM
27litres's Avatar
27litres 27litres is offline
If the ignition coils are working fine, there's no real need to replace them. They'll generate misfire codes when they fail.
However, I would trust an NGK replacement just fine.
48082 is the correct coil for the 5V 4.2.
Genuine Audi coils at FCP Euro are US$40 ea. I thought they were Bosch, but I cannot find an Audi coil in the Bosch catalogue, so I have no other brand suggestions.
If you stick with NGK, same coil at a lower price here
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 19th November 2020, 04:22 PM
revisiting this. just got around to replacing all 8 at a very reasonable £157 delivered from https://www.gsparkplug.com/
much smoother start/idle and running feels like I've found 20bhp
though I will concede that cylinder 7 had a slightly loose plug which may not have helped matters
