Old 17th March 2021, 09:29 AM
Ronin Ronin is offline
Default Meyle HD Control arm set
https://www.ebay.co.uk/itm/Meyle-Lin...IAAOSw~FZf-sli
Will this fit my D2 that has steel uprights rather than aluminium? From reading the forum I've read that the alloy ones have different lower arm tapers or something?
Old 17th March 2021, 09:59 AM
Both lower arms have different tapers on the balljoints. Meyle don't make a full kit for the 20" cars so you have to order all the arms separately unfortunately. They do specify a lower rear for the 20" but have no listing for the lower front - instead use one for a PF D2.
Old 17th March 2021, 11:50 AM
Thanks Mikki. So it makes even more sense now to go with alloy uprights but they seem to be quite impossible to find in UK..
Old 17th March 2021, 11:55 AM
Audi A8 D2 with FE 20" alloys as original factory fitment
1 off MEYLE 116 050 8293/HD TRACK CONTROL ARM Front RH,Rear,Upper
1 off MEYLE 116 050 8292/HD TRACK CONTROL ARM Front LH,Rear,Upper
1 off MEYLE 116 050 0140/HD TRACK CONTROL ARM Front RH,Lower,Rear
1 off MEYLE 116 050 0139/HD TRACK CONTROL ARM Front LH,Lower,Rear
2 off MEYLE 116 050 8228/HD TRACK CONTROL ARM Front,Front LH,Front RH,Lower
2 off MEYLE 116 050 8239/HD TRACK CONTROL ARM Front,Front LH,Front RH,Upper
2 off MEYLE 116 060 0006 ROD/STRUT STABILISER FRONT LH,FRONT RH
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 17th March 2021, 12:43 PM
Thanks! this will save me a lot of time
