ok,
so i blew the turbo Yes it broke in half and tried to get out of the side right mess ive bought a 2nd hand turbo in good condition fitted it using my own actuator car sounds good but is showing a fault my scanner shows this........... 13128 Activation turbocharger control module 1-J724 Electrical malfunction in circuit-sporadic 005-No or incorrect basic setting/adaptation found this on YouTube = Help ! https://www.youtube.com/watch?v=x7FnVxTEH3Q
Looking for the Holy Grail Audi .. 2018 VW Caravelle Executive T6 2010 A6-C6 3.0tdi LeMans Quattro |
Have you tried basic settings in VCDS? The ECU ought to be able to do it rather than having some dododad connected directly to the actuator. IIRC the actuator is driven by canbus which is why said youtube doodad appears to be working.
hi,MJ, i havent got vcds
a mate has thou , hes just got the whole shabang (is that a real word) anyway hes still learning, and im thick ! OOOH and it revs up good then the tick over is going up and down 500-1500 revs non stop brum brum brum brum switch off its ok again till revved up then same
Looking for the Holy Grail Audi .. 2018 VW Caravelle Executive T6 2010 A6-C6 3.0tdi LeMans Quattro Last edited by roberto; 17th November 2019 at 11:12 AM. |
I think every VAG owner should have VCDS, it soon pays for itself even if just used for scanning and clearing codes. Good luck sorting it. As MJ said, basic settings may sort it.
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
ill give my mate a call
ok, my mate came up with his new vag-com set up
hes a clever little devil too all sorted , car runs fine No warning lights etc Revs as it should... chuffed
Excellent
been out for a test drive
eml on limp mode crap ign off - on ran fine again then scanned same fault showing but revs well gutted mates comin up again sat
well it turned out to be a faulty turbo as it was 2nd hand and worn out and cheap so my fault......
So fitted a new recon one and its runs sweet and fast now no problems Cant wait for next track days
