House and Home DIY Everything at home. Building, Renovating, DIY, green initiatives, mowing the lawn. Anything goes |
I'm sure the combined brain power here can help with this.
![]() We have a fairly old gas boiler with an integrated mechanical 24-hr timer and switches that control heating and hot water patterns. This started to fail ages ago so I replaced (bypassed) it with an external 7-day electronic programmer (Drayton Tempus 7, no longer sold); wiring it in was a pretty simple bit of logic. The system is an old single-pipe circuit to the radiators and gravity-fed (i.e. convection) to the hot water tank. There is a tank thermostat (added by me) and wired wall thermostat that is in a bad location (due to later changes in the house that expose it to unusual heat and cold). I want to relocate the wall thermostat and thought that a wireless unit would be an improvement. So far, so good, plenty of choice there and many/most are programmable too. But the 7-day programmer for the heating and hot water is also a bit dodgy, the LCD display is fading away making programming more guesswork than anything else. Again, I can replace the programmer with newer models for a modest sum, £30-£40 seems to cover a good choice and there are plenty that say they are suitable for gravity systems. Then I thought, we're doubling up on the programming here, why not just get a modern integrated unit with a base wired to the boiler and wireless controller/sensor where it's convenient. Maybe even remote access for when we're away? That's when it all got a bit messy, the suppliers (I decide to start with Drayton for simplicity) when asked said that the integrated systems are ONLY for fully-pumped systems. Something I actually can't see the logic of. This is not a multi-zone system so the wiring for the controller is dead simple; power supply and two 2-wire circuits (heating and hot water) that are closed for on and open for off. They all (compatible and allegedly incompatible types) fit on standard baseplates with just those connections. (The current controller is already on such a baseplate.) Edit: Actually a bit simpler than that as the neutrals are all common. I've checked the original wiring, current controller wiring and potential replacements and all use the exact same pattern of two terminals (hot water and heating) that are made live (mains 240v AC) to turn that function on. Controllers are all double-insulated so only need 4 wires - Live, Neutral, Water, Heating. The ONLY potential problem I can see is that one "could" logically program the central heating pump to start without the boiler firing up. Our current controller has an installation option for gravity-fed that simply ensures that when the heating is turned on the hot water comes on too. Am I being logical here, or are there hidden complexities that I'm unaware of? As far as I'm concerned I could install a modern "all-singing, all-dancing" controller with wireless and remote access and all I would need to do would be to apply a bit of thought to the programming to ensure hot water was on when the heating was on. Even that wouldn't be really needed, it would be a doddle to fit a relay inside the boiler wiring box that just turned it on when the pump was energised. (Edit: Having studied the wiring diagrams I don't even need to do that, it's just a matter of rerouting a cable that takes voltage from the pump supply to trigger the boiler so that it will bypass the tank thermostat. CORRECTION, this would energise the pump when only heating water, so a relay is needed.) Thoughts folks?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 3rd March 2019 at 01:18 PM. Reason: Add a little more detail |
