Old 16th August 2022, 11:45 AM
Default It's enough to make a D2 owner weep.....
Many of us are fully aware of the challenges around removing and reinstalling door cards on a D2.
For those of a strong constitution and with lots of moral fibre, here's a short video of how Volvo do it: https://www.youtube.com/watch?v=dIiazVM1nyc
Note especially how the door pull is dealt with.
Old 16th August 2022, 12:00 PM
Visible screws! The horror!!
The B5 A4 and C5 A6 both come off like that too, the B5 being released just a couple of months after the D2. It takes less time to get the door card off an A6 than it does to gather the tools to prepare to take off a D2
Old 16th August 2022, 12:27 PM
First thing I spotted too.
But it is basically a Ford Focus in a posh frock!
Old 16th August 2022, 12:58 PM
But that's no challenge at all! How else would we pass the days?
Old 16th August 2022, 08:14 PM
GarethS8 GarethS8 is offline
I'm scared now lol, as I'm gonna attempt to change my door card on my d2 in a couple of week.
Plus Way to Many others
Old 16th August 2022, 08:18 PM
Just work up to it gently; First I'd start with changing the F125 as a "beginners challenge".
Old 16th August 2022, 08:46 PM
Ronin Ronin is offline
Removing and replacing door cards is easy.
D2 has a more complicated system than a ****ty mass produced ford that presses the door card against the door frame harder to aid with sound proofing(and also why there is a foam seal going all around it except for the top)
Old 16th August 2022, 08:56 PM
Indeed, I'm always surprised when I travel in my S8 with passengers and realise we're chatting to each other normally with minimal background noise in almost all road conditions and speeds.
In any other car you'd give up talking and just and turn the radio on loud. In my S8 the radio/music usually off unless there's something I particularly want to listen to. Apart from the V8....
Old 16th August 2022, 09:16 PM
If it's one of the rear ones, check out the following thread:
http://forum.a8parts.co.uk/showthread.php?p=85205
Removal of the front door cards will be quite similar.
NB: Be very careful when disconnecting the bowden cable from the door handle. Check out the 14th photo in the above thread, which shows a closeup of the end of the bowden cable, and is highlighted with an red ellipse. At the bottom of the ellipse you'll see a small greyish metal clip, and at the top of the ellipse you'll just about notice a small black piece of plastic at the end of the cable. Both of these parts are essential and are very easy to drop or misplace.
Old 17th August 2022, 09:02 AM
Sean,
You are a stickler for the finer points.
Well done and thank from everyone for your diligence.
All part of you extensive repair manual production experience of course.
