Hello I have a A8 d2 with a failing ECZ gearbox. Current symptom is converter shudder at low throttle around 2000-3000 rpm. I am wondering if I can replace this with a FUL box from an a6 4.2 2002? How would I know if they are compatible?
D2 A8L 4.2 AQF 4.2 LZ9W Ebony Black Pearl Fully electric rear seats D3 s8 front brakes s8 mirror housings 18x8 Avus 3 winter wheels PDC rear blinds Nav Electric steering wheel adjustment TPMS Leather pack 1 with retrofitted stitched leather lower dash panels folding auto dimming mirrors solar sunroof cold weather package CD changer double glazing all around memory seats passenger seat adjustment from rear seat Bose servotronic xenon plus headlights C5 Allroad 4.2 BAS 4.2 LZ6G Irish Green Metallic Bose RNS-E Rear Blinds folding auto dimming mirrors Heated MFSW with shift buttons PDC Recaros heated seats all around CD changer Nav B5 A4 STCC Edition AJL 1.8T Quattro Built engine GT28RS maxxecu Remote locking Trip computer Sport seats Eibach/Bilstein suspension Flexfuel C5 A6 1.8T Quattro AWT 1.8T Reliable, unlike the others ![]() Previous Audis B7 S4 Avant B5 A4 Avant 1.8T B8 A5 SB 3.0tdi C5 A6 1.8T C5 Allroad 2.5 TDI |
I reckon this will work just fine. What's critical with the 5HPs is final drive ratio, as the internals are all the same. The TCU is programmed to know what rpm should be coming out relative to gear selected and rpm coming in. If you have the same final drive between the two (which you do) the TCU will never know the difference.
ECZ transmission goes with DUR & EUS final drive 3.7:1 FUL transmission goes with EUS & GME final drive 3.7:1 |
MikkiJayne thank you for this answer. So for the basic function this would be a feasible swap. Next question then is if I should worry about any installation issues with mountings, electrical connectors or similar in mowing it from the A6 2002 to my A8L 2000. Also this is a used transmission said to be working before removal but I am planning on rebuilding it. Any recommendations on where to get a rebuild kit and what parts need replacing?
You will need to swap the D2 mounts and hardware over. F125 is the same.
I would get the converter reconditioned for sure because it sucks when you swap the transmission and then have to take it out again to replace the converter. Don't ask how I know that!! Clutch packs are fairly easy to get, mostly aftermarket now as I believe ZF have stopped selling parts for them. Exedy make some, and there are also some Polish kits. The main thing if you have it apart is to check the condition of the first roller bearing and first clutch basket snap-ring groove. If they are ok, new clutches and seals and it should be good to go. I've heard good things about the Transgo pressure valve upgrade too but not personally fitted one yet. If the replacement transmission is working then now is the time to fit the Transgo valve as it should prevent any pressure issues later on. |
Hello I have now bought the used transmission and also the transgo valve upgrade and also an upgraded A clutch basket. This first roller bearing you mentioned which bearing exactly is this? Do you have a PN or some source for it? I’m thinking I will just go ahead and buy one since when I start disassembling the gearbox I don’t want to get stuck having to wait for shipping incase something requires replacement.
this one:
There's an upgraded part from ZF compared to what was originally fitted. If you can find the ZF parts catalogue for the 5HP24a (its on the web somewhere) you can find the ZF number for this instead of the Audi one. |
Thank you so much
I've never touched the solenoids tbh, but if it helps in a BMW 5HP then I'm sure it'll help in ours too.
Has anyone the part numbers for complete gearbox and torque converter?
2001 S8.. just thinking Audi tradition may have them? |
Tradition have an S8 torque converter for a mere €1400. A few assorted 5HP24s for ~€7000, but no S8 versions.
