Old 8th August 2010, 06:23 PM
Mr K Mr K is offline
Default Engine management light on!
Driving home from a trip to summer set (camping and a car show) and I look down to see my engine management light on...
I dont have VAG com, the car drives absolutly fine with normal MPG and no misfires - i assume from this is probably coolant temp sensor or lamda sensors (one of my cats rattles inside - so lamda is hihgly likly).
Im not going to be able to reach a garage imediately to get it plugged in - seeing as it drives 'OK' will it be alright to get me to work?
Thanks in advance!
Old 8th August 2010, 09:43 PM
alefustec
Guest
Posts: n/a
Thanks in advance!
got exactly the same problem - light came on Saturday lunchtime, and like you no obvious problems as its also running fine (and also no vagcom lead!).........so would also appreciate the help!
Old 14th August 2010, 04:45 PM
It went into the garage at the weekend - the fault is as suspected related to the cat. Apparently due to a duff lamda it has put excess fuel through the right bank and burnt out the cat.
The fix- a new cat and lamda. I'm still deciding what to do as the cat is circa £700 from Audi and that sensor 150.
Old 14th August 2010, 05:16 PM
I believe (perhaps wrongly) that the old cats have quite a high trade in value. Worth checking out before you go bequeathing it to some lovely dealer
