Old 1st February 2012, 01:01 PM
gapthree3 gapthree3 is offline
Default Gruven parts 2" arms for sale
Does anyone require 2 X 2" Gruven actuator arms see www.gruvenparts.com.
I measured the gap at 2" broken when I should have measured fitted at 1".
They cost £73 landed and will cost £35 to send back so pm me for an offer.
1" on the way.
Yours, down on torque, gapthree3
Old 1st February 2012, 03:06 PM
Why do these vary in length? Is it 32v vs 40v?
Mines a 40v and pretty sure they're 2 inch from the very brief look I had when Reffro had the covers off to check they were working....
Adrian
Old 1st February 2012, 03:14 PM
I 'think' the C5 S6 has the different size ones.
Old 1st February 2012, 03:23 PM
If its not below zero when I put the car back in the garage later I'll pull the covers off mine and look
25mm seems awfully short from what I can remember
Old 1st February 2012, 07:03 PM
Mine is a 40V 2001 S8 which has variable valve timing (& is 1" arms). The gruven parts web site has a calculator for various models. I'm guessing 2" is for the non S8 engine.
I did get an e-mail from them to check the distance when I had placed the order. Unlike me, check the gap as though they arms are in place and not appart if they have snapped. Doh!
Old 1st February 2012, 07:12 PM
I think mine will be the longer ones and I need a set but I'll check on EtKa when I'm home later and get back to you, will definately make you an offer if they fit mine so pm me your contact details - cheers
Old 1st February 2012, 09:34 PM
Checked mine this evening and defo only an inch so no good to me
Takes seconds with nothing but a coin for tools so easy enough to pop the cover
