VCDS (aka Vagcom) For all your electronic debug / diag advice queries and mods. |
I had my 8 scanned today, below are the results.
Saturday,18,February,2012,14:37:40:10074 VCDS Version: Release 10.6.4 (x64) Data version: 20110418 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4D - Audi A8 D2 Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77 02 VIN: WAUZZZ4DZxxxxxxx ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No: 4D0 907 558 N Component: 3.7l V8/5V G 0001 Coding: 11753 Shop #: WSC 02313 VCID: 387B2CD332C3 WAUZZZ4DZ1xxxxxxx AUZ7Z0Y1xxxxxx 4 Faults Found: 16814 - Catalyst System; Bank 2: Efficiency Below Threshold P0430 - 35-10 - - - Intermittent 17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High P1131 - 35-10 - - - Intermittent 17977 - Cruise Control Switch (E45): Implausible Signal P1569 - 35-10 - - - Intermittent 16804 - Catalyst System; Bank 1: Efficiency Below Threshold P0420 - 35-10 - - - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.lbl Part No: 4D0 907 389 E Component: ABS/ESP allrad D46 Coding: 08397 Shop #: WSC 23132 VCID: 316D11F7D1B9 1 Fault Found: 01203 - Electrical Connection between ABS and Instrument Cluster 31-10 - Open or Short to Ground - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: VCID: 55A585678591 Note: Excessive Comm Errors ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4D0-959-655-AI8.lbl Part No: 4D0 959 655 T Component: Airbag Front+Kopf 4000 Coding: 01417 Shop #: WSC 02335 VCID: 43814B3F7B05 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: Part No: 4D0 919 035 AJ Component: D2-KOMBIINSTR. VDO D29 Coding: 00483 Shop #: WSC 02313 VCID: 6ED7CA8B0007 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8L0 862 257 P Component: CV-Pump, Alarm, RC D17 Coding: 13130 Shop #: WSC 00000 VCID: 428F4E3B641F 7 Faults Found: 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 00956 - Key 2 09-00 - Adaptation Limit Surpassed 00958 - Key 4 09-00 - Adaptation Limit Surpassed ------------------------------------------------------------------------------- Address 37: Navigation Labels: Redir Fail! Part No: 4B0 919 887 B Component: Navigation BNO 0001 VCID: 326F1EFBD4BF 1 Fault Found: 65535 - Internal Control Module Memory Error 00-00 - - ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: None Part No: 4D0 951 177 B Component: Innenraumueberw. D06 Coding: 00001 Shop #: WSC 00000 VCID: 285BFC93E263 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4B0-907-357-DYN.lbl Part No: 4B0 907 357 C Component: dynamische LWR D05 Coding: 00001 Shop #: WSC 00000 VCID: 285BFC93E263 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: None Part No: 4D0 035 195 Component: Radio D00 Coding: 00116 Shop #: WSC 02313 VCID: DFC9274F77AD 1 Fault Found: 00850 - Control Output Active; Radio Amplifier 29-10 - Short to Ground - Intermittent ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4D0-919-283.lbl Part No: 4D0 919 283 Component: Parkingsystem A8 RDW D07 Coding: 01108 Shop #: WSC 00000 VCID: E8DB3C93A2E3 No fault code found. ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01V-927-156.lbl Part No: 4D0 927 156 DD Component: AG5 01V 3.7l5V RdW 3838 Coding: 00001 Shop #: WSC 02313 VCID: 6ED7CA8B0007 No fault code found. End --------------------------------------------------------------------- All fault codes have been cleared and have not returned, only one which I think may cause concern are the lambda / cat related ones, should I be worried about these as they do say intermittent.
