Everything working OK otherwise?
Do you have B&O?
cubby hole has clips at the sides, not the top or bottom
![]() You sometimes need to run the CDs 2 or 3 times to make sure it got everything.
Almost there with the update....telephone is showing as not installed, but I'm just running disk 3 through now...hopefully that'll sort the last bits out ![]() ![]() |
Going relatively smoothly....although telephone & DVB don't seem to be working at the mo.
![]() Can a mod move this thread to the proper section when they get a mo? I posted in the wrong bloody place :confused: ![]() |
disk 2 needs run a couple of times to do the phone.. takes fookin aaaaaaaaages!!
DVB may have hit CP, but not sure, run all the disks again ![]()
tried running disk 1 again, but it says there's nothing to update. Disk 2 is running through again now
![]() Bloody pain in the bum if the TV has hit CP, but then again, I don't really use it, so it can wait until I can be arsed to go into a dealer ![]() Next job? fit the AMI unit ![]() ![]() |
dont worry the ami will only take 5 minutes
I assume you're doing the AMI as a parallel install rather than a swap? that's a bit more fiddle as you need to drop the globox out to run all the cables usually. Unless you really need to use the CD changer again, just swap it.
