Old 20th May 2012, 07:56 PM
Default Adjusting door shut position
Sounds simple, probably obvious, but I'm a wary soul.
My NSR door isn't closed to a good enough line, maybe as much as 3mm "open" at the rear edge, but secure.
A quick look at the mechanism shows a number of Torx heads on the door catch/slot and the striker plate/bracket on the body. No obvious movement marks anywhere, so maybe it's "crept" over time.
So I need the door to shut a bit "tighter", but which set of bolts do you undo, by how much, to move whatever needs adjusting?
