Old 5th August 2012, 04:49 PM
RanjS8 RanjS8 is offline
Default How to set timing on the Cams
Well I had the head apart on my AVP engine today to replace the valve on cylinder 7. Unfortunately I didnt mark the sprockets so I knew where to line up the cams with the timing marks.
Does anyone know how to position the cams in the right place..so the timing of the valves is right...thanks??
Here is a picture comparing the new valve to the old valve...
Old 8th August 2012, 03:55 PM
Default Found out how to set the cams at top dead centre
The image shows how to align the camlobes....The arrow should point to a little edged gap on the sprocket of the inlet and the output cam.
ID:	4187   Click image for larger version
ID:	4188   Click image for larger version
