Old 12th April 2013, 06:40 PM
A8Pete A8Pete is offline
Default Warning Light On. What does it Mean?
I have a 2004 Audi A8 4.0 Diesel Quattro. I have a new warning light appeared today. Picture attached.
Im not quite sure what it relates to. Is it the handbrake? Is it a brake pad?
Many thanks
Old 12th April 2013, 06:50 PM
darrenjoe90's Avatar
Its a fault with your electronic parking brake.
Audi S8 Phantom Black
Old 12th April 2013, 06:51 PM
Thank you.
Does it mean new pads needed?
Old 12th April 2013, 06:53 PM
It means you need someone to plug in a diagnostics computer to determine what the problem is.
Old 12th April 2013, 07:02 PM
Check the connections on them for corrosion, and make sure they're seated properly and try cycling it a few times.
Then, get someone to plug in and check the error.
Old 13th April 2013, 12:42 PM
Originally Posted by A8Pete View Post
Thank you.
No, that would bring up the brake pad warning light.
This is something a little more serious, a fault in the wiring or motor to one of the rear parking brake calipers maybe. Try putting the handbrake on/off with someone stoof by each wheel watching if the caliper actually moves. Computer diags is going to be the fastest way to see whats happening though....
