Old 25th April 2013, 05:28 PM
Paul r Paul r is offline
Default ecu location
Hi,
Where is the engine ecu located on the 4.2 tdi?
Cheers,
Paul.
Old 25th April 2013, 08:03 PM
There are two of them
But not quite sure where they live.. is there not a box in the scuttle tray in front of the windscreen?
Old 25th April 2013, 11:35 PM
ECU is item 1 on the following "Chart of Control Units"!
The housing for it looks like this - control unit is item 20
ID:	5939   Click image for larger version
Old 26th April 2013, 12:01 PM
Looks like a pain to get to??
Can anyone confirm if if the ecu is an edc16?
Cheers,
Paul.
Old 26th April 2013, 03:12 PM
there seem to be many listed so would need to refer to your engine code then chassis number to determine which ecu
Old 26th April 2013, 03:25 PM
I suppose it depends on the year, early ones are EDC 16CP34, later ones might be EDC17
Old 26th April 2013, 03:57 PM
And there's 2 for the 4.2TDi.. Is this for a remap perchance?
Old 27th April 2013, 06:55 PM
It's for a remap, yes. I need to make sure that the flash tool I'm buying is compatable with the ecu.
Paul
Old 27th April 2013, 07:38 PM
Best done with BDM
Old 28th April 2013, 04:08 AM
Best done with BDM
Why, appart from you can back up the entire ecu? Most places do it through the obd port.
Paul.
