Old 5th May 2013, 11:28 PM
Default Quick look at the D3 Fridge / Coolbox
There are two versions, a Coolbox at around £1000 for 5 seater cars that required a center pop up headrest, and a Coolbox with bar compartment for 4 seater cars with individual electric rear seats @ £1450 that instead of a pop up center headrest, comes with a glasses compartment with 2 glass tumblers.
I have the former in my 4.2 Tdi.
Note this is a proper refrigerated unit, not just a chilled feed from the A/C like you might get in the glovebox or similar. Its a very well insulated, electrically powered fridge that runs whenever the ignition is switched on. It does refrigerated remarkably well
The door, located between the two rear seats:
And with the door open:
And yes, it uses some space in the boot, but unless you carry singularly large items a lot, then actually the luggage space is still very sufficient and you can pack things around it easily:
ID:	6008   Click image for larger version
ID:	6009   Click image for larger version
Old 6th May 2013, 05:01 AM
it wouldnt be much good to me, on trips to france the boot is fully loaded and my current need for a double buggy and all the other crap babys need with them makes it impossible. i would also use it rarely
so why do i still want one it loooks very neat tucked in there
Old 6th May 2013, 08:25 AM
Yes - Double buggies are a killer, I remember those days
Still, like you say, doesnt stop you wanting it, even if you have no need for it lol
Old 6th May 2013, 02:32 PM
MAM MAM is offline
Whilst I would have loved to have the fridge in mine, it is a choice between carrying golf clubs or having a fridge. The golf clubs win out for me as the boot is not quite deep enough to fit a set of clubs straight in, and the battery and ICE areas stop you having the clubs across the boot.
Deep Green 2006 '56' A8 4.2 SE, B&O & Exclusive Interior
Extended Aluminium, Oak Sepia Wooden Trim, Extended Leather
Green Exclusive Dual Colour, Heated Comfort Leather Interior
Green Alcantara Headlining, Pillars, Rear Shelf, Door Inserts
Green Trimmed Mats, Seatbelts, Steering Wheel, Centre Armrests
DAB, Freeview, ACC, 4-Zone Climate, Soft Close, Electric Blinds
Old 6th May 2013, 03:44 PM
Nice. I also notice your left-side removable panel in the boot bulges out instead of in. Mine bulges in and has stowage net.
Is that due to the fridge's gubbins?
Old 6th May 2013, 04:03 PM
Out usually means TV etc. installed.
Old 6th May 2013, 04:55 PM
I have all that, TV, TEL, DAB, FM, and even then there is space to swing a mouse.
Old 6th May 2013, 05:27 PM
Or maybe the B&O amp takes up more space?
Both my D3s had the recess and net, but were both Bose.
Old 6th May 2013, 07:44 PM
The earlier cars with B&O had 2 amps mounted perpendicular to all the other gubbins, makes it stick out. Its like they were desperately trying to retain the room for the RSE DVD changer as theres a perfectly huge rectangular space left for it in there... !
Old 6th May 2013, 07:49 PM
The fridge is removeable, leaving a ski hatch so you can uninstall it just for those golfing days
