Old 22nd July 2013, 01:19 PM
Davie b Davie b is offline
Default Cruise control ...what next
Hi guys,
I've been having problems with the cruise control just not working , I tried the move the switches aggressively whilst swearing at it fix , but that didn't work .
I then bought a replacement stalk from a8 parts on fleabay , put that in and it still doesn't work , so what next ????????
Old 22nd July 2013, 01:46 PM
What model and year?
Old 22nd July 2013, 02:06 PM
Originally Posted by hpsauce View Post
what model and year?
s8 d2 1998
Old 22nd July 2013, 02:14 PM
If it's a PF, which it probably is, replace the cruise unit box.
I did that on my old (PF) S8 with excellent results. Thread here somewhere about it....
I spent ages analysing symptoms trying to decide if it was the box or the stalk. Eventually decided on the box (failed caps are a common problem on other Audis with the same system) and got one from A8parts.
Local VAG independent did the job as it's a bit of a PITA being at the very bottom of the box of electronics modules under the bonnet.
Old 22nd July 2013, 02:21 PM
Cheers mate ,
It is a PF , I've emailed a8 parts any way just to see if it was tested prior to selling
Old 22nd July 2013, 02:38 PM
Is there a way of testing the cruise control module through vag-com , I don't really want to go to all the trouble of changing it just to find out the stalk switch is faulty
