Old 30th July 2013, 08:05 PM
ur20v ur20v is offline
Default Problems with EBC Yellow Stuff pads and S8 Brembo calipers
Howdy y'all... I have a B5 S4 I have fitted with front Brembo calipers from a facelift S8. I purchased EBC Yellow Stuff pads for them, but when I went to install them, they didn't drop/slide in like the Textars that came with the calipers (I bought the calipers second hand). I had to file the powdercoat off the outer edges of the backing plates to get them to fit, and even then there was zero clearance - such a tight fit I had to tap them in place against the piston faces. I double and triple checked that I got the right pads for the application through EBC's catalog and my supplier and they are indeed correct. Now I have noticed that the metal shim on the outer pad on my right side has unglued itself and is migrating toward the wheel hub. I fixed it once a few weeks ago, but it has started moving again.
Has anyone had similar fitment/quality issues with EBC pads and their S8 calipers? Or EBC pads in general?
Thanks a ton!
Old 31st July 2013, 07:55 AM
Sorry Ton i can't help as i have no Brembos but i'm sure Darren had EBC on his S when he had it. Someone will be along to help soon. Been quite quiet here the last couple of weeks.
Old 31st July 2013, 08:02 AM
Mine has Brembos but with Mintex pads so I cannot advise. Sorry.
Old 31st July 2013, 10:39 AM
Reffro Reffro is offline
I used to run EBC Red Stuff on my old S8 and had exactly the same problem. Each time I needed to file off the excess material to ensure the pad could slide freely. I seem to remember Darren having the same problem with his Yellow Stuff pads.
Old 31st July 2013, 03:50 PM
darrenjoe90's Avatar
Yes I had the same problem and had to use an angle grinder to clean off the edges of them. The time before that I had them fitted by a local independent and he forced them in and that caused me loads of problems. Best to grind them off and make them fit nice and slack
Audi S8 Phantom Black
Old 1st August 2013, 04:17 PM
Thank you gents! Glad to know I don't have faulty pieces
