Hi,
So.... wife took the a8 today (first mistake?) and when she returned it there was a noticeable misfire. The cat light is on and otherwise runs alright. I suspect a failed coil - unburned mix then causing the lambda to go out of limit flagging the cat light. I have vcds and will scan the car tomorrow. Anybody know different or seen before? 1997 ABZ 4.2. DM |
Scan for which cylinder the missfire is on. Swap the coilpack with another cylinder and scan again. If it moves, new coilpack.
^ +1 if it doesn't move could be the plug breaking down.
1996 A8 4.2 QS. Bose, Solar roof, um...um... rally sport towbar. Now gone to a new home as the Traders 8. Bright yellow bus o love. Last edited by Dezzy; 30th October 2013 at 10:59 AM. |
The other way to check which one if you don't have a scantool/vagcom/vcds is to sequentially pull the coil pack conector off and place back on while the engine is running, you'll hear a change in sound if that cylinder is doing anything and no difference otherwise. Quite a useful diagnostic trick....If you have the tools it also confirms the connections to the packs.
ok .. so..
Misfire on cyl 3 diagnosed by vagcom and confirmed by pulling injector connectors sequentially. Removed coilpack #3 and replaced with #1. Misfire continues on cyl#3 - again confirmed by injector clip. Removed plug#3 and replaced with #1 - misfire continues cyl#3 I've ruled out coilpacks and plugs. Here is the VCDS log prior to me starting: Wednesday,30,October,2013,16:57:26:54668 VCDS Version: Release 11.11.6 Data version: 20121223 Chassis Type: 4D - Audi A8 D2 Scan: 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77 02 Mileage: 306910km/190705miles ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4A0-953-234.lbl Part No: 4A0 953 234 Component: IMMO AUZ9Z0B0291186 D77 Coding: 00000 Shop #: WSC 00214 VCID: DFC326F75DE890E0F91 1 Fault Found: 01176 - Key 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 4D0 907 557 J Component: 4,2L V8/4V MOTR AT D01 Coding: 04263 Shop #: WSC 00214 VCID: 336B1A4701E0E480ED9 6 Faults Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - Intermittent 16500 - Engine Coolant Temp. Sensor (G62) P0116 - 35-10 - Implausible Signal - Intermittent 00561 - Mixture Adaptation 15-10 - Adaptation Limit (Add) Not Reached - Intermittent 01088 - Mixture Control Adaptation 2 15-10 - Adaptation Limit (Add) Not Reached - Intermittent 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-00 - 16687 - Cylinder 3 P0303 - 35-00 - Misfire Detected Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4D0-907-379-ABS.lbl Part No: 4D0 907 379 L Component: ABS/EDS BOSCH 5 7680 Shop #: BB 37680 VCID: 37732E57159808A0D11 1 Fault Found: 00526 - Brake Light Switch-F 27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: Redir Fail! Part No: 4D0 820 043 A Component: D2-KLIMAVOLLAUTOMAT_D02 Coding: 00081 Shop #: WSC 23146 VCID: 1A35D7E3864A35C8CEF No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8A0-959-655.lbl Part No: 8A0 959 655 K Component: Airbag V AUDI D00 Coding: 01022 Shop #: WSC 02314 VCID: 3B7B326729B02CC0359 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4D0-919-033-MYW.lbl Part No: 4D0 919 035 C Component: D2-KOMBIINSTRUMENT__D16 Coding: 00483 Shop #: WSC 00001 VCID: 264DF313C23281287A7 No fault code found. ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: None Part No: 4D0 927 156 E Component: AG4 GETRIEBE 018 D27 Coding: 00000 Shop #: WSC 00000 VCID: 2B5B0227D9D0BC40A59 1 Fault Found: 00526 - Brake Light Switch-F 03-00 - No Signal End --------------------------------------------------------------------- The 16500 g62 coolant seems spurious as once cleared did not return. 00561 - Mixture Adaptation 15-10 - Adaptation Limit (Add) Not Reached - Intermittent 01088 - Mixture Control Adaptation 2 15-10 - Adaptation Limit (Add) Not Reached - Intermittent These two are a symptom of the missing cylinder I believe. 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-00 - 16687 - Cylinder 3 P0303 - 35-00 - Misfire Detected I don't see evidence of any random misfire - every time I cleared codes these two came back. The only exception was when disconnecting the injector these two were replaced with: 1 Fault Found: 17611 - Fuel Injector for Cylinder 3 (N32) P1203 - 35-00 - Electrical Malfunction Tomorrow I will continue by checking the injector and best to do a compression check to rule out any mechanical issue. |
Also where are the amplifiers / power stages located?
On the 20v turbo 5cyl cars they are on the bulkhead. I will swap them round and see if the miss stays put. |
