Old 25th March 2014, 04:39 AM
Bandycoot Bandycoot is offline
Default Injector upgrades
A recent compression test on my FL S8 revealed an engine in rude health even after 180,000 miles. However, I feel the injectors could be past their best. If I'm going to change them I may as well upgrade them at the same time. Does anyone know what injector upgrades are available and suitable? I'm not too worried about any increase in fuel consumption as petrol in Dubai is only 28p a litre.
Thanks
Steve
2001 D2 S8. Volcano black. KW Variant 1 coilovers. EBC Turbo grooved discs with Yellow Stuff pads. 19 inch R8 replica wheels with 255/35/19 Michelin Super Sport. In the UK, 1990 Audi 90 2.3 20v Quattro with just 65,000 on the clock and in mint condition.
Old 25th March 2014, 05:27 AM
Anything below 10% increase in flow there is no point changing and anything above 12% will require re-mapping.
Old 25th March 2014, 06:30 AM
B@fink B@fink is offline
Erm.........So would that be 11% then?
Old 25th March 2014, 12:24 PM
yes 11% sounds good lol
Old 26th March 2014, 06:05 AM
Green Goblin's Avatar
Green Goblin Green Goblin is offline
Hmm, wonder how much power could be had with bigger injectors on my S8. Already has aftermarket exhaust with sports cats and x-pipe. I'm thinking bigger injectors, freer-flowng air filter and MRC to map all the mods. 370-375ish?
Old 26th March 2014, 01:31 PM
I don't think you will see much if any improvement from injectors. Stock injectors normally have reserve fro 20-30% extra power. You only need bigger injectors once you get to close to the limit of what they can deliver. And even then you can increase fuel pressure to get higher delivery rates. There is really no need to change injectors on NA engine unless you do major changes like manifolds and camshafts.
Old 26th March 2014, 03:54 PM
Thanks! That's really good advice, I did think the stock injectors are fine. Also they are only £25 each.
I'm really interested to hear the fuel pressure can be increased, can this be done with the stock pump?
I think I read in ElsaWin that standard fuel pressure is 3.5bar?
The reason I ask is that I have a dream of a bigger displacement engine swap in the distant future, and that engine would need 60psi or a little more.
Old 26th March 2014, 04:39 PM
£25 each? Surely that cannot be right. I bought one from dealer for AHC engine couple of years ago as I could not find one elsewhere and it was around £140.
Fuel pressure regulator for AHC is 4 bar which is highest VAG make I think. It could be lower on other engine codes and if so you could swap in one from AHC engine otherwise it will need to be aftermarket market one and you could get adjustable as well. If you increase pressure by much say to 5 bar or more you will most likely need beefier fuel pump as well.
Old 26th March 2014, 06:54 PM
That's excellent! I think 4 bar will be fine. Its just a pipe dream anyway, not likely to happen. The engine I'm interested it is GM's LS3 6.2 litre, its quoted as requiring 60psi which is around 4bar.
I hope its not my memory going bad, it was for the S8 I sold, I took it to MRC and one injector was suspect, they originally quoted something close to £200 but when I came to pay the bill they said the actual price was something like £25. I could hardy believe it too.
