Old 24th September 2014, 10:58 AM
Phil303 Phil303 is offline
Default Gearbox Flush
At 113,000 miles S8 has gone in for a fluid change today - gulp. Hope it doesn't lead to premature death. The garage have ordered in new *everything*; flanges, seals - the works.
If you don't hear any more from me regarding this, assume the gearbox is okay!
Old 24th September 2014, 11:28 AM
sarg sarg is offline
Fingers crossed for you
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 24th September 2014, 11:31 AM
Mine should be getting done on Friday for 2nd time in my ownership
Old 24th September 2014, 01:41 PM
Hi Phil,
Where did you take your S8 for the Gearbox Flush?
Matt
Old 24th September 2014, 07:50 PM
Surlingham Garage in.... Surlingham.
They were recommended to me by my father-in-law over 10 years ago and I've used them ever since. Neither cheap nor expensive but the level of service is excellent. I guess that's why they're busy despite being a little out of the way.
If you're thinking of having it done I'd definitely recommend them, especially as they've just done mine so know exactly what's involved for next time. They appreciate having unusual or rare machinery to work on.
I dropped the car off in the morning, drove off in one of their loan cars and by about 2.30 the car was finished.
They've got a website; drop Kevin an email or give him a call. Mention my name and that you'd like the same thing done and take it from there.
Old 25th September 2014, 05:41 AM
My fingers are crossed for you too, as it sounds like these guys, good as they are, probably won't have the correct equipment to flush and filter the oil and the right temperature. Mine's getting done for the second time in my ownership (and it was done once before that), but I've used a specialist with the right machine.
Old 25th September 2014, 07:05 AM
Mine only gets the 'dump what's in there warm, remove sump and change strainer, then refill with correct temperature box' method - but mine's got so little mileage on it the original oil would probably still be alright and it's only done 17k miles since I had it done before
Old 25th September 2014, 10:48 AM
I have read on here the various degrees of flushing but I'm happy that they did the best they could with what they had.
They did spend some time going through the advised procedures beforehand as it's a car they don't get in often - or at all. They work on newer, more complex Audi's every one in a while but nothing this old.
I knew beforehand that they don't have the specialist equipment to properly cleanse the 'box but at least been done at some level. There was nothing wrong with the car before but it does feel a little slicker now, although I'm not 100% it's just my mind playing tricks.
When I first considered the S8 and initially turned it down they were suprised. Apparently they had bets on how quickly I'd buy one after expressing an interest in getting one. They know me better than I know myself.
Old 6th October 2014, 06:45 PM
Right, gearbox flushed etc but now I have a whine at low rpm when cold. After a search on Google it threw up the likely answer to be something to do with the Torque Converter and/or ATF Pump. Here's the symptom and problem as nicely described on another forum (AudiNet I think):
Many tend to make noise with age no matter what...esp at cold idle and low speed.
Mine's a fairly quiet whistle/whir that I only hear at idle and low revving (not past 1500rpm) in P or N, which gets higher pitched with rpm...nothing once I'm moving...I've just accepted it, since the trans works at 100% in all respects..never a thump, slip or hard shift...
Anyway, under the torque converter, at the front of the trans, is the ATF pump...sometimes a notorious noise-maker...some have called it the "D2 Kazoo". A restricted atf filter can overwork the pump causing it to whistle/whir/whine...this is why it’s often recommend to cut off part of the pick-up tube on a new filter installed (they are very close to the bottom of the pan...I measured about 7mm on mine with correct OEM filter).
Also some can make noise due to "cavitation"...air bubbles in the fluid, sometimes caused possibly by overfilled trans foaming the oil...or even overheated or contaminated ATF.
It could also be an installation error. When they bolted the motor/trans together they did not pushed the TC against the flex plate, they used the 3 TC bolts to pull the TC. It creates a tension in the flex plate. The only way to fix it to loosen the 3 bolts and re-tighten them.
Anyone else have this and found that the above is the solution?
Old 6th October 2014, 06:49 PM
I seem to remember seeing somewhere that there are 2 different filters and if you fit the wrong one it is too close to the bottom of the sump and makes the pick up struggle to work properly so it may well be that - check the part number on your filter and make sure it is correct because if it isnt you may be doing the change again
