Old 9th January 2015, 10:58 PM
pwacka8 pwacka8 is offline
Default 4.2TDI, Flahing glow plug light ,cut out on motorway
Hello Again
Some of you may have seen my 4.2TDI not starting thread ,anyway since then it has been running and starting fine.
I have been down to Surrey this week for work so travelled down on monday from liverpool and no issues at all , the drive was great.The tank was full when i set off and was down to just under 3 quarters when i got to surrey.
Friday afternoon set off back up north and had a lovely drive until i got to the M62 turn off from the M6 , the glow plug light started flashing and the cruise turned off, it then ran for about a mile and then died on the M62 slip road.
The tank was just under half way which is about where it was when it stopped starting a few weeks ago.
Had my laptop in the boot so scanned it
Friday,09,January,2015,19:28:44:62939
VCDS Version: Release 12.12.0
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 4E1 910 409 B HW: 4E1 907 409 A
Component and/or Version: 4.2L V8TDI G000AGMª0010
Software Coding: 0011773
Work Shop Code: WSC 02313 785 00200
VCID: 23450907E2202306A91-8076
4 Faults Found:
004195 - Fuel Pressure Regulation
P1063 - 001 - Control Range Not Reached
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 144571 km
Time Indication: 0
Date: 2015.01.09
Time: 19:06:09
Freeze Frame:
RPM: 1722 /min
Torque: 280.8 Nm
(no units): 5.0
Tank Cont.: 34.0 l
Voltage: 14.21 V
Pressure: 151.8 bar
Duty Cycle: 37.5 %
P1063 - 002 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 144571 km
Time Indication: 0
Date: 2015.01.09
Time: 19:06:09
Freeze Frame:
RPM: 1722 /min
Torque: 280.8 Nm
(no units): 5.0
Tank Cont.: 34.0 l
Voltage: 14.21 V
Pressure: 151.8 bar
Duty Cycle: 37.5 %
P1063 - 006 - Control Range Not Reached - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 144571 km
Time Indication: 0
Date: 2015.01.09
Time: 19:06:09
Freeze Frame:
RPM: 1722 /min
Torque: 280.8 Nm
(no units): 5.0
Tank Cont.: 34.0 l
Voltage: 14.21 V
Pressure: 151.8 bar
Duty Cycle: 37.5 %
P1063 - 005 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 144571 km
Time Indication: 0
Date: 2015.01.09
Time: 19:06:09
Freeze Frame:
RPM: 1722 /min
Torque: 280.8 Nm
(no units): 5.0
Tank Cont.: 34.0 l
Voltage: 14.21 V
Pressure: 151.8 bar
Duty Cycle: 37.5 %
Readiness: 0 0 0 0 0
Would i be right in saying it looks like fuel starvation?
Cleared the codes and try starting but now its just turning over.
Got recovered and its back on the path.
Is the fuel tank in two pieces ? im wondering if a pump is not transfering fuel from one side to the other????
So when the fuel in one side is used thats it!
Any ideas???
Thanks in Advance
PWACKA8
2012 4.2TDI SE EXEC
