Old 11th October 2015, 06:39 PM
Norretal's Avatar
Norretal Norretal is offline
Default Beeeeeep
Not sure if I'm posting in the correct place, but here goes....
Can't find anything else relating to the same issue on here so I'm asking for guidance. Since yesterday I've had a warning when putting the car into reverse, the continuous beep and asking if it's safe for me to reverse. The only thing I did was wash the car yesterday and the fault arrived just after. So, is it a failed sensor and is the only option to replace it? I'd obviously be happier if it's a common thing and there's a cheap, easy fix
Audi TT - 2015 - Ultra
Old 11th October 2015, 06:50 PM
Could be just water in the connector, do you know which ones not responding
Old 11th October 2015, 07:01 PM
Norretal's Avatar
I don't have VCDS Del but I can get it scanned if that's what is needed. It's not really a problem, just more of an annoyance, I'd like to understand and fix it
Old 11th October 2015, 07:44 PM
Is it something your going to tackle yourself, the bumper can be a right pain in the behind to get off.
You may be able to determine which one is out by listening to them when reverse is engaged.
Old 11th October 2015, 10:11 PM
47p2's Avatar
47p2 47p2 is offline
Did you use a power wash to clean the car?
Nite Blue 3.0L SE Quattro
Old 12th October 2015, 08:18 AM
Norretal's Avatar
Yes I did, but lightly just to rinse as it wasn't really dirty, is that a known cause?
Old 12th October 2015, 09:44 AM
47p2's Avatar
...is that a known cause?
Yes, never point a jet washer at the parking sensors, if they get a tiny amount of water in they are fubarred, had one on my Mercedes went haywire because of water ingress, and managed to reset it by connecting to diagnostics, not sure if this is possible with the Audi or not
Old 12th October 2015, 02:41 PM
Norretal's Avatar
I've washed it many times using the same method, guess I've just been unlucky this time.
Thanks, I'll get it scanned and find out which one is acting up
Old 12th October 2015, 08:38 PM
You see, I always knew it was possible to over wash a car.... I've always been a bit cautious like that....
Old 12th October 2015, 09:18 PM
Norretal's Avatar
Thanks for the helpful guidance Ian, I knew I could rely on you
