Old 17th May 2015, 08:44 PM
Default Advice from those "up North" or there regularly
This Friday, which as we know is the start of a Bank Holiday weekend, I have a journey to make and need help/advice.
Starting down South in the morning, first stop Peterborough. I know the best way to go and we'll be there a while. Should be leaving there late morning or about midday.
Final destination, hopefully by about 5pm (no point arriving before 4pm anyway) is Far Sawrey near Hawkshead in the Lake District. Usual approach is round the Southern end of Windermere.
All the computerised route planners say A1, M62, M6. They must be joking!
I'm thinking A1, off at Wetherby along A661 to Harrogate and A59 to Skipton then A65 to M6 J36 and finally A590 etc.
Any opinions from locals/regulars?
Old 17th May 2015, 08:52 PM
That route will literally go past my front door. It'll be scenic, but quite slow.
A much faster route would likely be up the A1, and across the A66. That's the route I'd be taking.
The A59 from Harrogate heading west is a slow going single carriage way with little overtaking opportunity and plenty of unmarked cars just in case you get the chance
Old 17th May 2015, 09:18 PM
Thanks Ian. I did consider the A66 (and I've used it many times before) but it ends up way too far North. And I've been along the A590 many times.
We could cut down from Brough to Tebay, but even then it's a fair bit of messing about to get to Hawkshead. Though doable I guess - South down the M6 and over to Kendal (or the A685 scenic route?) then whichever way we fancy.
What about the A684 (again we've done that before) via Bedale, Leyburn, Hawes, Sedbergh......
Minor correction, it's Near Sawrey we're heading for, a whole 1km further!
Old 17th May 2015, 10:16 PM
Errr…what's your start point? ("Down South" is a bit non-specific, when it comes to giving guidance…). Also, when are you setting off from home? I'm a bigger fan of the West Coast routes if you're going to the Lakes, but i'm biased...
Old 17th May 2015, 10:22 PM
Reread the first post.
first stop Peterborough. ........................................ Should be leaving there late morning or about midday.
Old 17th May 2015, 10:51 PM
So…not 250m from HS2 then ...? I'd still suggest getting onto the M6 north asap, better to come across on the A50, than come across on the M62 further North (at any time really…)
Old 18th May 2015, 08:26 AM
Home is indeed 250m from a planned HS2 tunnel. (It was only 50m until they realigned it)
But we are effectively starting from Peterborough as we have to go there first on the way up (but not on return - heading for North Wales ).
Did the A50/M6 version of the route last year, October time, and the M6 north of Stoke was awful both going up and coming back, though A50 was fine. Bailed out onto minor roads eventually.
So you reckon the M62/M61 westbound should be OK mid-afternoon? And get past Manchester OK?
