Old 9th February 2015, 03:53 PM
Duffy Duffy is offline
Default EPB Faults - final shot in the dark!
Hello
I've had regular fault codes coming up for my S8, namely
02596 - Rear Brake Pads Worn
008 - Implausible Signal
and
02438 - Right Parking Brake Motor Hall Sensor
008 - Implausible Signal - MIL ON
which I can't clear.
I've just done discs and pads, done the full VCDS adaptation process for the pads and the function test several times, all of which has made no difference, the brake works perfectly, voltages across both calipers are good.
I've checked both connectors, both were immaculate inside, I've continuity checked between the control unit and the caliper, again all good.
Any suggestions/thoughts before I invest in a new caliper? It's only done 49K and looks nearly new........
Sir Wil, can I have my D2 back?????????
1988 Audi 90 2.2E
2011 Mercedes E250
2016 Abarth 595 Competizione
2012 Porsche 981 3.4S PDK mid life crisis!
Old 9th February 2015, 05:38 PM
Default Did you cycle the ignition when doing the procedure?
I seem to remember reading something about the ignition having to be turned off at some point in the pad change sequence, was that done?
Old 9th February 2015, 05:51 PM
The procedure was followed to the letter..............made no difference and seemed to go perfectly, it just didn't clear the errors.
1988 Audi 90 2.2E
2011 Mercedes E250
Old 9th February 2015, 06:22 PM
The hall sensor on the motor being out would possibly lead to the motor not being exactly sure where it is and as a result, not sure if the pad is as thick as is claimed.
Old 9th February 2015, 06:24 PM
I suspect you're right.
I've just repeated the whole process and checked that the pad thickness adaptation had taken (it had) and just checked the brake switch function as there are a couple of yank threads re this causing issues, it's working fine.
New caliper time.
My calipers are painted black, that'll equal a couple of hundred extra pounds from Audi!
Are all S8 rear calipers the same?
1988 Audi 90 2.2E
2011 Mercedes E250
Old 9th February 2015, 06:38 PM
Could you not replace just the motor?
Old 9th February 2015, 07:01 PM
I didn't know the motor came seperately is the answer to that.
I've not got access to an up to date ETKA
Thanks!
1988 Audi 90 2.2E
2011 Mercedes E250
Old 9th February 2015, 07:08 PM
Sir WIll Sir WIll is offline
The D2 continues to be a lovely everyday car and the rear brakes are working just fine with no fault codes
Though one of the plastic tubes for the windscreen washers popped off! I mean, how dare it go wrong!
Old 9th February 2015, 07:12 PM
An outrage entirely due to sloppy workmanship on the part of the previous owner!
I replaced them and the scuttle at some point I'm sure!
1988 Audi 90 2.2E
2011 Mercedes E250
Old 9th February 2015, 07:14 PM
I think during a frozen morning last week the nozzle was not working and it popped off.
I mean it took at least 10 seconds to fix and now has a zip tie on for good measure. That's the trouble with these expensive Audis they just need to be constantly looked after
