Old 12th July 2009, 01:03 PM
Default Starter Motor Won't Crank
As you may of seen I broke down on Friday and was recovered home.
While on a tea break driving home the car failed to start. A motorist gave a me a jump start and I quickly ran VagCom and noticed the voltage was really low at tick over (11.2V) and didn't increase when I revved the engine.
Classic alternator failure symptoms. Anyway decided to risk continuing the journey on battery alone, switched everything off and went on my way. Made it another 60 miles with Vagcom plugged in monitoring the voltage. Watched it steadily decrease until 9.8V the ABS and engine management light flicker and came on and at 9.3V it went into limp mode. That was enough and I got RAC out who took me home.
Whipped out the battery and gave it 48 hour charge (only got a 2Ah charger). Back in the car and nothing! Battery was then checked professionally and given a clean bill of health (almost 800A). Looked pretty new, definitely not the original.
Getting a click from what sounds like a relay under the bonnet but no cranking.
Wondering what it can be. Hope to hell it isn't the starter motor as that is a bitch to replace as you need to remove the engine mount to get to it.
Wondering if a duff alternator impededs starting or if there is a relay somewhere???
Anyone any ideas?
Car is now at home and I am away again for a week so will be next weekend before I can have another look.
Old 12th July 2009, 02:37 PM
I'm assuming that given the recent work you've done, the connection point for the main power wire is OK.
Could be a relay, but given that you're hearing the click, it suggests that the starter solenoid is engaging, but it doesn't think it has enough power to start.
Have you tried a jump-start? Could be that your battery looks OK on the test, but can't really deliver the juice required to start.
Old 12th July 2009, 06:39 PM
That thought is nagging me. I have a mate with a land rover. I'll get him to pop over next weekend.
