Is it possible to turn the message about the steering lock off when the ignition is turned off? Problem is, when it beeps every time I leave the car, I don't realise that I've left my lights on. Came to the car this morning with no battery power t all. So much so that when I tried the key in the ignition, it now won't release.
Alternatively, is there a way to code the lights to automatically turn off if the headlight switch is left in the on position? I was able to do this in my last passat, but have found coding options very limited on my D3 |
It's never been something that I've looked into because of auto lights but I have never seen mention of coding for delay in headlights, I am surprised that the battery's flat though.
Would have expected the battery manager to shut it off instead of continuing to flatten the battery. I don't think the auto light retrofit is difficult to do and would cure the issue for you.
Del ![]() |
I have the auto lights, but last night was foggy on the way home, and had to use them (never normally do), meaning I had left the switch in the headlight position.
In my passat when I changed the lights to a Scandinavian setting for DRL, it allowed the light switch to be left in any position and they would still turn themselves off. I remember coming across a similar setting on the Audi somewhere, tried it but it didn't work. There was other options like North American etc, so I'll maybe try my luck with some of those. |
