Can anyone explain exactly how the brake pad wear system works on an FL D2?
Mine came on part way home from The Meet, but went off after an overnight park up at home. Then came on somewhat later. Visually all pads look OK with a fair bit (several mm) left though the front discs are badly scored and will need replacing. It seems to stay on once on but isn't on after an ignition cycle, presumably a "lock" somewhere that resets after an ignition off. Nothing showing on VCDS so I'm guessing this is simple circuits/relays or similar. After hearing various tales about dodgy wiring near the brakes or (worse) deeper in the car I decided to test it yesterday as I had a couple of 40-mile journeys to make. It stayed off through many miles of driving as long as I only braked gently and used the gears/engine to slow down most of the time. Corners, bumps and other movements had no effect, ONLY applying the brakes reasonably firmly. So how exactly does it work - e.g. wires embedded in the pad that are shorted by the disc? And is this an MOT fail or just advisory - assuming the brakes otherwise work OK. Mine is due fairly soon I think.
