Morning all,
The front end of the '8 is starting to knock over uneven surfaces, had a play with a pry bar and the front end, lower rear arm seems rather slack, so I think the bottom arms need replacing. I have paperwork to suggest the upper arms were replaced earlier in the year prior to my ownership so it's them or ARB. Are the bottom arms a job I should be attempting and can achieve on the driveway? Am I going to run into pinch bolt issues or anything like that? Any advice appreciated! Thank you, Ben
Current: 2004 D3 4.0 TDI V8 in Crystal Blue. Factory: finger print, tv, xenons, keyless entry & go, soft close boot, 19s, and probably lots more besides Done: fixed headlight washer leak, fit Bluetooth in place of factory phone To do: DAB, DTV, fix soft close boot, get a spare key, investigate NSF bushes, |
