Have any members had their ABS unit rebuilt, specifically the electronic half? Who did you use?
ABS Lights are on and there's no VCDS communication, the last retrieved fault code was 01203 - Electrical Connection between ABS and Instrument Cluster 03-10 - No Signal – Intermittent Searching tells me this is a generic Bosch part used in various VAG cars including the A4 B5 and A8 D2 and this type of failure is well know that there is even a rebuild kit from the Dealer. However, I've found this company and the price seems ok. http://www.ebay.co.uk/itm/Audi-A4-AB...-/400442033788 Used ABS units are slightly more expensive and may have the same problem. Other than above there is also the DIY route which seems a bit crude by cutting into the case. http://www.cardiagnostics.be/-now/ABS%20VW%20Passat.htm
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 21st February 2016 at 08:01 PM. |
