Old 18th March 2016, 12:59 AM
Rick Rick is offline
Default what are my music playing options with mmi ami etc
All i have is the 6 cd changer at the moment.
I have picked up a 6 disc dvd changer with a view to get that fitted at some point as the boy seems to be gutted he cant watch movies like in the ST, im sure that aint a straight fit.....will need some widget or lead somewhere...
Do I have any other options for plugging in anywhere to play music from my phone or would i need to fit another gizmo like an AMI unit or something?
Are there any spare sockets or things located in any of the existing units like av1 or av2 as that shows up on the tv screen although i havent actually seen them i believe they are in boot left hand side under the nav unit.
There really is alot of car to investigate and learn!!
Thanks.
Old 18th March 2016, 06:37 AM
mannyo mannyo is offline
Rick, does your car have a TV tuner. If the answer is no, then getting any video input into the MMI is going to involve replacing the main MMI module with one that does have a video input.
Again, to get music in you either need an AMI module or if you have TV then you can get a bluetooth dongle and plug that via some adapter cables into the tuner AV inputs.
Manny
Past
Old 18th March 2016, 06:54 AM
Yes I have the tv tuner.
Is there a particular lead/plug i need to get for these av ports? Or are they just the small coaxial plugs?
Old 18th March 2016, 07:41 AM
Also while im thunking... how do i find out uf im 2g or 3g mmi.
Old 18th March 2016, 07:48 AM
3G has a little joystick on top of the main MMI knob. Didn't come out until mid 2008.
You will have a navigation DVD-Rom drive in the boot, left hand side if its 2G.
If in doubt, post photo of MMI screen or MMi buttons
Old 18th March 2016, 08:40 AM
Ah well it must be 2g then as mine is a 2006 model. Thats that sorted!!
Cheers!
Old 18th March 2016, 08:54 AM
I would go down the AMI route. Yes it's a tad pricey for a new unit at £260ish with DIY install - but you wouldn't regret it.
As for streaming, John has had success with a Tune2Air connected to the AMI
http://forum.a8parts.co.uk/showthread.php?t=11142
And Mike with his install here
http://forum.a8parts.co.uk/showthread.php?t=9628
AUX 1 & 2 probably wont be wired in. You'll have to buy the phono leads and insert the end pins into the red connector on the TV unit to actually use AUX 1 & 2. You can also remove the speed delimiter to allow video in motion.
http://forum.a8parts.co.uk/showthread.php?t=9139 - AUX guide
http://www.ebay.co.uk/itm/400779555363 - Cable for each AUX
https://trick77.com/tools/mmi2g_vimcode.php - enable VIM
Do you have DAB? You may as well install that while you're at it!
Matt
Old 20th March 2016, 06:55 PM
I dont know if i have dab to be honest.
I get a few dvb channels.
Old 20th March 2016, 10:29 PM
If you have DAB radio then when you go to the screen where you choose your frequency then it should say DAB radio along with FM, MW, LW etc
Old 21st March 2016, 07:38 AM
Oh ok cheers!
Will have to look in a bit then though i dont recall seeing dab before.
Need to get to an owners meet sometime!
