Old 9th May 2015, 04:04 PM
zed_thirteen's Avatar
zed_thirteen zed_thirteen is offline
Default Parking sensor optical display not working
I've swapped my 4E0 919 283 A module for a 4E0 919 283 C module in my 2003 D3.
I checked module 76 coding and it was already showing a 2 for the second digit. All of the other coding for the unit was good too but I can't remember it all off hand.
The sensors are working but I'm not getting the display on the dash.
My MMI is at the highest level.
Is there something else I need to code or enable in the MMI?
Thanks
David
Old 10th May 2015, 05:10 AM
In the settings for the parking sensors should be an option for the display type on the MMI
Old 10th May 2015, 12:24 PM
I can't find any other settings for the MMI. I have the MMI hidden menu enabled and I can't find anything in there. My parking module coding is: 0201108
My MMI is at software version 5570. I've been through the 3 software update CDs again and all reported no updates required. I've performed an mmi soft reset too.
My VCDS logs are:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 34 36 37 38 42 46
47 4F 52 53 55 56 57 61 62 72 76 77
VIN: WAUZZZ4E03N004951 Mileage: 102350km/63597miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Sporadic communication error 1000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 D HW: 4E0 907 560
Component: 3.7L V8/5V G 0060
Revision: 00000000 Serial number: AUX3Z0BD106427
Coding: 0011773
Shop #: WSC 02312 785 00200
VCID: 224B0C03FD3A2A0EA27-8077
1 Fault Found:
18284 - Valve for Torque Support Mount
P1876 - 004 - Open Circuit
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 A HW: 09E 927 156
Component: AG6 09E 3,7L5V RdW 0060
Coding: 0000001
VCID: 204F060BF336381EB43-8075
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0400
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 2149030FF83C3116BBD-8074
1 Fault Found:
00526 - Brake Light Switch-F
011 - Open Circuit - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H01 0070
Revision: 00703201 Serial number: AUX3Z0BD106427
Coding: 0264192
Shop #: WSC 02311 785 00200
VCID: D8BFEEEB6BE630DE0C3-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00172 - Key 2 not learned
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 5
Fault Frequency: 2
Reset counter: 50
Mileage: 164176 km
Time Indication: 0
Date: 2015.04.24
Time: 12:07:58
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 B HW: 4E0 959 760
Component: Sitzmemory BFS H05 0020
Revision: 00000000 Serial number: 5DS 008 795-02
Coding: 3670016
3 Faults Found:
01877 - Belt Height Adjustment Button (E333); Down
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 66
Mileage: 33444 km
Time Indication: 0
Date: 2015.05.05
Time: 07:25:42
01876 - Belt Height Adjustment Button (E333); Up
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 66
Mileage: 33444 km
Time Indication: 0
Date: 2015.05.05
Time: 07:25:42
01332 - Door Control Module; Passenger Side (J387)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 14
Reset counter: 36
Mileage: 0 km
Time Indication: 0
Date: 2002.01.01
Time: 00:00:00
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300LL027513709
Coding: 0000002
Shop #: WSC 59152 001 1048576
VCID: 3A7BD46375AA42CE9A7-806F
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 322KK027502509
Subsystem 3 - Serial number: ÿÿ12.11.02ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 011 0190
Revision: 00000009 Serial number: 00000000007827
Coding: 0020545
VCID: DABBF4E315EA22CE3A7-808F
6 Faults Found:
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 20
Mileage: 147941 km
Time Indication: 0
Date: 2014.09.04
Time: 14:47:24
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 7
Reset counter: 35
Mileage: 162661 km
Time Indication: 0
Date: 2015.03.13
Time: 09:18:09
Freeze Frame:
Temperature: 17.0°C
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 9
Reset counter: 64
Mileage: 163111 km
Time Indication: 0
Date: 2015.03.25
Time: 16:52:29
Freeze Frame:
Voltage: 13.70 V
(no units): 72.0
(no units): 255.0
00020 - Motor for Blocking Flap; Defrost and Body Vents; Right (V199)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 68
Mileage: 164563 km
Time Indication: 0
Date: 2015.05.06
Time: 07:27:26
Freeze Frame:
Voltage: 13.10 V
Temperature: 10.0°C
(no units): 72.0
(no units): 75.0
Temperature: -90.0°C
00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 42
Mileage: 164008 km
Time Indication: 0
Date: 2015.04.20
Time: 07:27:33
Freeze Frame:
Voltage: 13.50 V
(no units): 0.0
(no units): 0.0
00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 164451 km
Time Indication: 0
Date: 2015.05.01
Time: 07:35:06
Freeze Frame:
Voltage: 13.70 V
(no units): 216.0
(no units): 254.0
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 A HW: 4E0 907 279 A
Component: ILM Fahrer H11 0070
Coding: 0010001
VCID: 264310139112D62ECEF-8073
Subsystem 1 - Part No: 4E2 910 113
Component: Wischer WWS D3 H30 0310
Coding: 00000036
Shop #: WSC 02311
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H08 0840
Coding: 0431707
Shop #: WSC 02313 785 00200
VCID: E3C5C90722A0E306691-80B6
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H08 0020
Coding: 0112141
VCID: E5C1D71F2C949D36875-80B0
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 C
Component: KOMBIINSTR. VDO H38 0020
Revision: 992703 Serial number: AUDID3BD000608
Coding: 0000403
Shop #: WSC 00185 067 57207
VCID: DCB7F2FB1FDEDCFE28B-8089
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H06 0040
Revision: 06 Serial number: 0000302B2915AF
Coding: FCFE7BDC2B3504
Shop #: WSC 00000 000 00289
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 6
Reset counter: 74
Mileage: 164723 km
Time Indication: 0
Date: 2015.05.08
Time: 18:30:30
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBB1007573
Shop #: WSC 00000 000 00000
VCID: 1C3732FBDF5E1CFE68B-8049
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0264192
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 50
Mileage: 164176 km
Time Indication: 0
Date: 2015.04.24
Time: 12:07:58
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 C HW: 4E0 907 553 C
Component: LUFTFDR.-CDC H03 4190
Coding: 0015500
VCID: 23450907E2202306A91-8076
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H05 0020
Coding: 3670018
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 364BX087760684
Shop #: WSC 00477 128 65295
VCID: 3B75D1677A907BC6811-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0060
Serial number: 00000232200124
Coding: 0035856
VCID: 1D313FFFC44415F69F5-8048
4 Faults Found:
01370 - Alarm triggered by Interior Monitoring
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 50
Mileage: 162608 km
Time Indication: 0
Date: 2015.03.12
Time: 16:54:00
Freeze Frame:
Bin. Bits: 00000000
02160 - Lamp in Sunroof Switch (L65)
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 0
Fault Frequency: 15
Reset counter: 75
Mileage: 164672 km
Time Indication: 0
Date: 2015.05.08
Time: 07:48:00
00212 - Control Circuit for Reading Lights Front Left
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 230
Mileage: 0 km
Time Indication: 0
Date: 2015.03.31
Time: 17:03:00
00213 - Control Circuit for Reading Lights Front Right
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 230
Mileage: 0 km
Time Indication: 0
Date: 2015.03.31
Time: 17:03:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.FS BRM004 0060
Coding: 0026914
VCID: DEB3F8F309C2CEEE46F-808B
1 Fault Found:
02110 - Window Regulator Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 164528 km
Time Indication: 0
Date: 2015.05.05
Time: 07:55:42
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 HW: 4E0 907 289
Component: Komfortgeraet H02 0050
Coding: 0000729
VCID: E6C3D013D192962E8EF-80B3
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H01 0020
1 Fault Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 35
Mileage: 115528 km
Time Indication: 0
Date: 2012.11.18
Time: 13:47:17
Freeze Frame:
Raw, Form. N/A: 000 000 000
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H12 0460
Revision: PROD_01O Serial number: 00000000055584
Coding: 0000017
VCID: 2A5BE423850AF24EEA7-807F
1 Fault Found:
02084 - Component Protection
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 162
Mileage: 161852 km
Time Indication: 0
Date: 2015.02.21
Time: 15:17:38
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0050
Revision: Serial number: 00000000006974
Coding: 0010101
VCID: DDB1FFFF04C4D5F65F5-8088
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.BF BRM004 0060
Coding: 0026914
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000331
Shop #: WSC 00011 888 96745
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Revision: 00000001 Serial number:
Coding: 0000001
VCID: E2CBCC033DBAEA0E627-80B7
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304LQ027511595
Coding: 0000001
VCID: 3169F34FA8DC81962BD-8064
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 253
Mileage: 145715 km
Time Indication: 0
Date: 2014.07.31
Time: 10:59:05
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 G HW: 4E0 919 146
Component: TV analog TUNER H11 0300
Revision: 00000006 Serial number: 00000000000000
Coding: 0001003
VCID: 2541171FEC14DD36C75-8070
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: ENERGIEMANAGER H12 0480
Revision: 00000000 Serial number: 00000000011440
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1211280464
Coding: 303030393135313035414B56413031323131323830343634
Shop #: WSC 00185 210 88124
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0060
Coding: 0026914
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0060
Coding: 0026914
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720528501085
Coding: 0201108
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H18 1130
Revision: 00000000 Serial number: 00000005070940
Coding: 0010920
VCID: 2C57E23B8FFEEC7E18B-8079
End ---------------------------------------------------------------------
Old 10th May 2015, 06:23 PM
Sorted it.
Had to update MMI Control Unit module 07 adaptation channel 1 to add the front acoustic parking sensors and rear acoustic parking sensors. I hadn't considered doing this because the acoustic side of the system was working fine.
Anyway, after adding bits 2 and 3 (12) to the original value I then got the optical parking aid displayed on the MMI screen - well after another MMI reset I did.
Thanks for the help guys. Hope this helps someone else too.
Old 10th May 2015, 06:27 PM
Somerandomguy's Avatar
I think you need to go into the MMI menu on the car rather in VCDS to enable the display. I think its is the car..systems menu
Old 5th August 2016, 01:32 PM
ulfilias ulfilias is offline
Just fitted one of these C boxes and it worked straight off. Am guessing that the car may have had one fitted before and someone cheapskated or sold the upgrade seperately!
Nice and useful upgrade for me as I have to park the car next to a wall where other cars are also parked, which means an acoustic sensor is full on and you have to guess distance!
Lee
Tags
optical, parkhilfe, parking sensors, pdc
