Old 15th August 2016, 08:38 PM
SilverS8 SilverS8 is offline
Default Those beloved fault codes again; 17972,17966,17521
Good evening
Just back from a 1000 mile trip, and even though the car felt mostly ok, I felt it lacked some power now and then
No lights in the dash but the fault codes when running VCDS below.
3 Faults Found:
17972 - Throttle Actuator (J338)
P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
17966 - Throttle Actuator (G186)
P1558 - 35-10 - Electrical Malfunction - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1
P1113 - 35-10 - Internal Resistance too High - Intermittent
Readiness: 0000 0000
Just to mention that my MAF is only a few months old (OEM PART)
17972 : I have done Throttle adaptation without any luck. I did look at my TB readings and find them a bit odd.
TV Sensor 1 16% (should be between 0-10 it says)
TV Sensor 1 at WOT is "only" 85%
Is my TB about to go on a permanent vacation?
17966 Same as the above? (found nothing on the forum for this code)
17521: Broken O2 pre-cat sensor? UK Driver or passenger side?
Any way to read meas.block to see if one is failing?
All tips apprecaiated
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
