Old 9th September 2009, 10:05 AM
ulfilias ulfilias is offline
Default Fault bits
Hi Guys,
I've finaly after a load of messing about got one of the dodgy cables to play ball with 3.11 - Old but hopefuly it'll give me an idea of how much use/worth there is in things.
I've scanned, then cleared, then run arround a bit and scanned again and been left with :
17927 - Camshaft Adjustment: Bank 1: Malfunction
P1519 - 35-00 - -
17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
I've had a Engine check light since i bought it and was told that it was due to the LPG installation and nothing to worry about....However i'm always sceptical.
Anyone explain the above ??? - Is it worth getting that Lambda sensor replaced (they are on the exhaust i belive as with ramps probably not a big job ?)
Ta,
Lee
