Old 31st December 2016, 09:02 AM
1781cc 1781cc is offline
Default calibrating pad thickness
anyone know what the settings are for the D3 S8? helpfully its not on the VCDS Wiki...
http://wiki.ross-tech.com/wiki/index...#Pad_Thickness
Note: When replacing this Control Module it is necessary to perform the Basic Settings Function Test (MVB 010) and Longitudinal Acceleration Sensor (MVB 020) first. This sets a Readiness Bit for each of the Basic Settings, Coding will not be accepted without having done this first! Make sure to adapt the Brake Pad Thickness after Coding the module.
0000?xx: Engine
1 = 3.0l MPI (Gasoline)
2 = 3.0l TDI (Diesel)
3 = 3.7l
4 = 4.0l
5 = 4.2l
6 = 6.0l
0000x?x: Transmission
1 = Multitronic (VL30)
2 = Automatic Transmission (AL420)
3 = Automatic Transmission (AL600)
0000xx?: Country
1 = Rest of World (RoW)
2 = USA/Canada
3 = Japan
