Old 4th May 2014, 05:36 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default MMI Remote
Going through ETKA and came across a MMI remote.
Anyone seen one or know anything about it?
Part number
4E0 035 207 C - Remote control.
[center]
06 3.0TDI Quattro:
Options:
Old 5th May 2014, 07:18 AM
darrenjoe90's Avatar
I have one of these. It also comes with a separate remote for the rear seat entertainment. All fits in the rear center arm rest. I can show you a pic when i get home from work.
Audi S8 Phantom Black
Old 5th May 2014, 12:38 PM
ScottD3's Avatar
That be great if you could thanks.
[center]
06 3.0TDI Quattro:
Options:
Old 5th May 2014, 01:00 PM
Hi Darren
Is it really something you would use for MMI??
Rear seat entertainment I get it, but MMI couldn't be any closer, could it??
Old 5th May 2014, 01:19 PM
ScottD3's Avatar
Something for the passengers to do?
If they felt the ride was to harsh, they might want to make it comfy.
[center]
06 3.0TDI Quattro:
Options:
Old 5th May 2014, 01:30 PM
Aaaaaaaaaaaaaaaaah, I get it, BUT NO!!!!!!!!!!!
NO ONE IS ALLOWED TO PLAY WITH MY CONTROLS, unless they are behind the wheel which is IMPOSSIBLE
Old 5th May 2014, 06:34 PM
it wont just work on any MMI, i think you need the rear seat entertainment, if you look in elsa you will see references on how to pair the remote with the car, but from memory the button is only on equipment for the rse
Old 5th May 2014, 08:37 PM
ScottD3's Avatar
Remote control: activating, initializing and testing
Activating the remote control
– Insert the correct batteries in the remote control: → Owner's Manual.
– Press any key on the remote control.
A red LED should light up on the remote control.
– If the red LED does not light up, check the batteries and ensure they are properly inserted.
– After the batteries have been installed, the remote control must be initialized.
Initializing the remote control
– Switch on ignition.
– Press the -C- button on the digital TV tuner -R171-.
To do so, use a 2.5 mm hexagon key or similar.
– Simultaneously (or at least within 1 second) press the “MENU” button on the remote control.
– Switch to “TV” at the multimedia operating unit -E380-.
“TV” should appear on the front information display unit -J685-.
– Check if anolog TV reception is available.
Please note that analog TV reception may vary according to your current location.
– Switch to “External AV source” at the multimedia operating unit -E380-.
“External AV source” should appear on the front information display unit -J685-.
– Connect up the vehicle diagnosis, testing and information system -VAS 5051 A-.
– Carry out self-diagnosis for TV tuner -R78- → Chapter.
Can't see much on ETKA about different TV tuners or remote based tuners.
[center]
06 3.0TDI Quattro:
Options:
Old 22nd July 2014, 08:38 PM
Couple of people have asked me if they can see a pic of my MMI remote so here it is. It fits in the armrest next to the Alpine rear seat entertainment remote as you can see in the pic. Also i think it works via bluetooth as you do not need to point it anywhere for it to work. If anybody wants to have a look at it then i will be at AITP
ID:	8613   Click image for larger version
Old 1st August 2014, 07:56 AM
Darren can you post lots of pictures for me for the RSE ..im half way through retro fitting it and I might be missing some connectors in the boot there seems to be a red connector and a brown one that have no where to connect into ?
I have seats installed wired up I can turn them on but I only get a blue screen saying navigation.
Any ideas ? In the boot is there an extra box or is it just plumb straight into the tv tuner ?
