D3 - Common Faults Quick links to all known common faults and their solutions |
After successfully changing a turbo on 4.0 D3, it was running. Brake fuild warning light came on (car was jacked up at the front). Fluid was added, however message to seek assistance came up on the display. Scanned with Gen Ross tech VDSC:
18259 - Powertrain Data Bus P1851 - 000 - Missing Message from ABS Controller - Intermittent 18255 - Please check DTC Memory of ABS Controller P1847 - 000 - - Intermittent 18262 - Powertrain Data Bus P1854 - 000 - Hardware Malfunction - Intermittent 18289 - Powertrain Data Bus: Missing Message P1881 - 000 - Acceleration Request - Intermittent The rear pads recently showed as low too on the scan. Any advice would be appreciated, should a be checking fuses?. ![]() Steve
2003, A8 D3 4.0 TDI |
