Having read about it happen to others it finally happened to me!
I experienced the amazing feature of Audi design, where if the car was locked with the key fob and the power supply is cut off, you cant unlock the boot physically with the key. It was my fault really, I kept using the Webasto heater for 25 minutes before each day's driving, and I guess with the cold weather and everything the little lithium battery just was not getting charged enough after all that heater use. So I finally pushed it over the edge and caused the low voltage cut off to kick in. Came back to the car and no power. The battery low voltage cut off is an ingenious system with one flaw (due to being in the boot). The battery circuit switches itself off to keep enough capacity to start the car. All you have to do is press the ‘on’ button ![]() I could unlock the driver’s door manually and all the other doors. Luckily I have a ski-hatch with all the stuff removed. Using a wooden stick I managed to pry open the battery compartment door. Still couldn’t see the button. So I taped a small mirror to the stick and moved it around until I could see the battery ‘on’ button. But how do I press the button? I decided I need a L-shaped stick long enough to reach the button. Luckily I had a cheapo metal broom stick with a plastic end and a hole to hang it up. Fishing around for something to jam into it to make a L-shaped stick I found an old plastic compass with a plastic screw-on cap to hold the pencil. So with a bit of fiddling this formed a ‘finger’ at the end of the broomstick to press the button. After several tries (you have to hold down the button for a second or two to turn the battery back on) I managed to do it, pressed the key fob unlock and the boot opened. Phewwwwww! Now I know what a nightmare it must be to have the battery die and unable to open the boot. What a stupid design feature! |
This cutoff and "on" button is presumably a feature of your specific lithium battery?
You deserve the Inspector Gadget or McIvor (was that his name?) prize for that Goran!
The lock will be seized, should be able to free it off with some WD40 (and some force, or strip and clean depending on your approach) and then use it periodically and problem solved
Indeed, there is a direct mechanical link from the lock barrel and, AFAIK no "deadlock" mechanism.
Sounds like you have some sort of mechanical problem that needs investigating, probably in the lock barrel or linkage.
Almost certainly the barrel - my previous fix on a number of Audi's involved a good dose of WD40 and some brute force on the key (mole grips) - goes with a crack and then it works fine afterwards. Risk of that approach is snapping a key - less risky approach would be to strip and clean the barrel
That's odd, because when I locked the car manually after removing the battery for a bit of home charging, I could lock and unlock the boot easily with the key.
I hope I wasn't just being thick, but the key definitely would not turn in either direction just after the battery went flat. When I have some time I'll try to re-produce the problem I am now curious what the boot actually does in a power loss situation. The low voltage cut off is a feature of this particular battery, but I vaguely remember seeing some such add-on circuits for Lead acid starter batteries too. I'll take that McGyver award thanks ![]() ![]() Last edited by Goran; 24th January 2017 at 02:21 PM. |
Was it cold and just frozen?
You need to turn anticlockwise then a bit further and then push in to open. Alarm will probably go off too, though with the battery "hibernating" who knows...
It was not frozen. The key would literally not budge in either direction.
Then with battery removed, locking manually and unlocking manually smooth as anything. |
Odd. It sort of suggests you had either a different boot lock fitted to your car at some point, or you were trying to open with the valet (non flip) key, both of which would behave how you describe....
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
