Old 12th June 2016, 09:24 PM
omlilleby omlilleby is offline
Default Ticking noice at 1800-2000rpm
Hi.
I have a ticking noice at ca 1800-2000 rpm, the noice is coming when i run on flat ground and have almost no throttle. Also downhill with zero throttle, braking on the gears. Under acceleration,slow and fast i cant hear anything.
Took an comression test all ok, and took of the valve cover, and on the bank 1 syl 1-4 the chain tensioner had a worn groove from the chain and oil around it,outside cover.
Can that be a broken tensioner causing the ticking sound?
Cant hear anything with a stethoscope on the engine.
Hav no fault code on VCDS.
Just changed oil, no difference.
Its the AQH engine.
Or does anybody have another solution on my problem?
