Old 27th July 2017, 09:14 AM
Default Audi A8 4.2 Quattro Sport 1996
Silver with black interior, usual sport extras
One of the last 4 speed cars, I've had it for just over 2 years and done about 9k in that time.
145,720 miles recorded which will rise as I'm using it. There is some service history though not enough to verify the mileage.
I've sorted some of its issues but, as usual, it keeps providing more.
Cosmetically it's a 10 yard car. Most panels have had attention at some point from persons of variable talent.
Interior is pretty good though typically the centre armrests are missing.
It has MoT until 4th May 2018 and does drive quite well.
The tyres are fairly recent (< 3k) and are a huge improvement though not a premium brand.
In my ownership
- New thermostat and coolant flush.
- Breather hoses replaced (non-original)
- Oil and filter changes
- Gearbox oil change
- OSF wheel bearing
- Rear suspension links, track rod ends and 4 wheel alignment.
- Brake caliper slides freed and lubricated
- Various minor electrical gremlins dealt with.
- Drains cleared
- New tyres
The issues:
-Engine oil leak(s). I've done the cam covers, which were leaking, but the big leak(s) seem to be from the camshaft oil seals, especially the RH bank.
- Recently started clonking from front right. One of the balljoints no doubt.
- A/C only holds gas for a few days. Condensor has been renewed, suspect evaporator. System works well when there is gas in it.
- Windscreen cracked. Not in drivers field of view. I can get this renewed on insurance if someone wants the car as a going concern.
- Ignition key different from the rest.
- Brake pad warning light on (pads fine)
- Airbag system non-functional. Has resisted repair - ECU/sensor and seat belt pre-tensioner replaced. Only one fault code remaining relating to the warning light itself - which works!
- Occasional ABS warning light. Clears if switched off/on. May happen twice in one day or not for 9 months.
I will be sad to see it go as I like driving it and it's never let me down. However, I have a C4 A6 as my daily driver and also a full blown restoration project (Triumph GT6) on the go, so really don't have the time and energy spare to deal with it's outstanding issues and the inevitable OCD-related mission creep!
Entry level A8 ownership for the mechanically able..... as a rolling restoration or drive-home parts donor (pity IMO, not so many left now).
£ 750 - ish or reasonable offers. Car located in south Somerset (TA13)
PM on here or mail at nick(at)tengaston(dot)plus(dot)com
ID:	16617   Click image for larger version
ID:	16618   Click image for larger version
ID:	16619   Click image for larger version
ID:	16620   Click image for larger version
ID:	16621   Click image for larger version
ID:	16622   Click image for larger version
