"No key identified" keeps coming up on the DIS whenever i try to start the car now.I have changed the battery in the key and it has had no effect. I tried disconnecting the battery for a few hours.
There were a few reasons for this. The auto darkening mirrors were dark all the time when the ignition was on, the key wasnt getting recognised and the AMI doesn't work. It seems to have remembered what was on the USB drive nearly a year ago and only plays those tracks, no matter what is on the USB drive, you can completely remove the USB from the AMI and it still thinks those tracks are stored on it. I'm totally sick of the music that I have been listening to for the last year and given that I spend several hours a day in the car it is distressing! I thought disconnecting the battery for a while with the AMI set on bypass and the USB removed might wipe whatever weird memory thing it has. Anyway. disconnecting the battery sorted the mirrors as it always does, but AMI is still being a dick and the car still isn't recognising the key (with new battery). I tried a VCDS scan but the non official copy I bought is utter sh**e. It doesn't communicate with 90% of the control modules. Total waste of money. On a previous scan which seemed to work better, i seem to remember it saying there were a couple of the key recognition antennae not working. Are they replaceable items and where are they? I hate having the key in the ignition. Having it swinging against my leg for hours gets really annoying. For info, the keyless entry has never worked since I've had the car, the finger print scanner has never worked but the button has always started the car until yesterday when it started with its key not recognised nonsense. Do any of these cars work for more than five minutes?! |
Where do you live mate..I can run a diagnosis for you.. I have vcds and Odis as well.
Previously: 2010 Audi A8 4E Quattro Sport TDI Oyster Grey Currently: 2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey |
That's very kind of you to offer, unfortunately I would struggle to live much further away from you, I'm up in the wilds of Scotland.
I'm happy to report that the key issue seems to have resolved itself. It's all working as it should (except for the keyless entry, but thats due to faulty door handles). The car has a mind of its own sometimes. The AMI thing hasn changed and is way more annoying. Imagine listening to the same few albums over and over for 6 months with no end in sight haha. I ownder if the MMI software just needs updating. I have ordered an update DVD for the navigation, does this do the whole thing? I have VCDS but it was a.. erm... non official copy. Itr desnt communicate with 70% of the control modules on the car which is obviously next to useless. It works better on the laptop rather than the tablet but the battery is knackered on that... new one n the post! gill |
In my opinion, your problems were caused by the battery, that was with a low level of charge. The energy management system of the car disconnects sequentially the less vital systems to ensure the start of the car. Concerning to the AMI, the DVD navigation doesn't update the AMI. Please download the file in the link below AMI driver update which contains the update procedure (in german) and the latest firmware of the AMI (.bin file). Anyway, I have the update procedure in english, but I can't upload the file, so I paste here the content of the document: Update for Audi music interface This update is used to replace the driver for the Audi music interface. This may be necessary due to new generations of media players or due to new firmwareversions. To perform the update, you will need a standard USB stick with sufficient free memory space (at least 2 MB) and the USB adapter (available from your Audi dealer). Please work through steps 1-7:
Now remove the USB stick and the USB adapter. Your Audi music interface is ready for use again. Hope that it helps. Cheers from Spain |
Muchas gracias desde Escocia!
I have actually been calling it an AMI but its a Dension. However, thanks to your post I looked for firmware updates, which I successfully installed. It didnt make any difference unfortunately but I used the USB stick which I had used originally in the car to install the update. I had deleted the music from it but oddly the menu still showed the music folder and all the tracks. When I looked inside the USB stick on the computer it had two BIN files on it. It appears that the Dension thing writes the track listing onto the USB stick and it will only see the music that is in this menu. When I had previously changed the music on the other stick, I hadnt deleted the BIN files so it only saw the music that was on that list. I now have access to all of the music that I had put on the stick. Now that I know its working, I think I will get a USB hard drive and just put all my music on it. Thanks again, I would never haver gone down that route without your advice. |
