Old 6th November 2017, 09:02 PM
RS6's Avatar
RS6 RS6 is offline
Default Wanted! Door Card wooden trims
Plastic trim that goes on x4 doorcards wanted please around the electric windows, any colour and condition considered normally wooden effect or similar
Door Panel Switch Trims
Drivers Side & Passenger Side doorcards - wood trim wanted any shade or colour
Rear doorcards - wooden trim both sides with ash tray wanted both sides please
X4 in total
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 6th November 2017, 09:09 PM
James, I have these but the switch panels are the rubbery plastic variety not the painted metal surface that looks like veneer, as I think you may know.
I think you're planning to coat them with a carbon fibre look so not sure if they are suitable.
Old 6th November 2017, 09:14 PM
RS6's Avatar
RS6 RS6 is offline
Hi Andrew can you post a picture off what you have?
This is the set i ordered but those x4 trim pieces were not inclulded sadly - https://www.ebay.co.uk/itm/Audi-A8-D...72.m2749.l2649
This is what i need and the rest really - https://www.ebay.co.uk/itm/AUDI-A8-D....c100290.m3507
correct i am carbon fibre wrapping all the trim, once a set is done, i will have another full set of trim that can also be wrapped
Old 6th November 2017, 09:21 PM
Here you go, the four unwrapped switch panels in this picture (ignore the interior light which is not part of the trim set, though I have that too).
The set you bought probably doesn't have the switch panels because they are requested much more than the other items.
Old 6th November 2017, 09:38 PM
Real carbon or vinyl?
Old 7th November 2017, 12:34 PM
RS6's Avatar
RS6 RS6 is offline
I think for real carbon it has to be dipped or treated, so these will be be professionaly wrapped gloss carbon effect instead, this should work well enough
Andrew that looks just the job, are the clips ok underneath, no damage etc?
if you could sell me x4 parts
Old 7th November 2017, 12:41 PM
All good, I removed them (very carefully!) from my current S8 myself. See PM sent today.
The colour is called Twist by the way. Will you want them with or without switches and ashtrays?
Old 7th November 2017, 01:06 PM
Close-up high-res pictures attached, from above and below.
The rears also include the lower grab handle shells if you want them, not sure why I ended up with those!
Both those lower shells have small cracks in (highlighting markings visible in photo) but still fit fine and securely.
(I think they are particularly prone to damage due to the force needed to fit/remove so they may actually be better than yours; the front ones are easier.)
ID:	17463   Click image for larger version
Old 7th November 2017, 09:05 PM
RS6's Avatar
RS6 RS6 is offline
Will probably need everything with them switches and ashtrays looks just the job
Old 26th November 2017, 04:03 PM
RS6's Avatar
RS6 RS6 is offline
Sold
Actually no longer need these if any body is interested let me know
