Old 21st February 2018, 10:58 AM
Trootfashermin Trootfashermin is offline
Default Sat nav latest Dvd
Looking for some advice, just recently procured an s8 but it never came with a sat nav DVD! Anyone know where the best/ cheapest place to get one? (most up to date version)
Old 21st February 2018, 12:29 PM
This is the one you need, assuming you don't have 3G with an HDD which will only be the case if you've got a late facelift (different mini joystick on top of the MMI click wheel)
http://forum.a8parts.co.uk/showthread.php?t=13783
Old 22nd February 2018, 11:04 AM
Appreciate that! It's late 2006 model I have with the DVD changer in the glove box will try and burn it to a disk and see if it works thanks !
Old 22nd February 2018, 12:10 PM
Nav drive DVD should be in the LH side of the Boot behind the panel with the recess and net on it - the Dash drives would normally be CD multi changers for the Sound System
Old 23rd February 2018, 05:44 AM
double check that the nav disc will eject - not uncommon that the transport lock hasn't been removed as part of the PDI. Can be sorted with VCDS if not, or local dealer if you use them for service
Old 23rd February 2018, 05:45 PM
I'm offshore just now got my mate to check he ejected it and out popped the original disk popped it back in and bingo it loaded!! thanks guys. would it the updated version work if it was just burnt onto a disk and popped in?
Old 23rd February 2018, 07:41 PM
Yep
