Hey guys need your input on this please.
So for over a year now, my driver side heated wing mirror hasn't been working. VCDS reveals the following error message: Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 F Component: Türsteuer.FS BRM005 0180 Coding: 0028462 Shop #: WSC 02313 785 00200 VCID: 20486A13F3B91341C9-8074 1 Fault Found: 00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 0 Reset counter: 233 Mileage: 138176 km Time Indication: 0 Date: 2017.06.28 Time: 23:35:28 I have run several diagnostics and it has costed me quite a bit. I was able to source a replacement mirror on ebay same as the original but that didn't fix the issue. Next I checked the wiring between the mirror and the door control module ecu, and that seems fine as there is continuity running thru the wires after checking with a multimeter. And lastly, I replaced the door control module with a replacement but unfortunately that still didn't fix the issue. Can anyone shed some light on this please. The Passenger side heated mirror works fine.
Previously: 2010 Audi A8 4E Quattro Sport TDI Oyster Grey Currently: 2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey |
