Old 13th April 2018, 03:02 PM
Default Front top suspension arms
I need to replace all 4 arms and have been quoted £148 inc VAT for each arm. See attached for part numbers and quoted prices, top line includes labour.
I think that is an ok price for OEM but are they available any cheaper? Any recommendations for parts and also a garage for fitting, I won’t be taking her to my usual place after a disappointing last visit.
MJ......!?
ID:	18424   Click image for larger version
Old 13th April 2018, 03:05 PM
jamoca's Avatar
jamoca jamoca is offline
You'll be able to get Lemforder or TRW ones (both OEM) cheaper than that - Lemforder from mister-auto or TRW ones from ECP. Lemforder are slightly more than TRW but I've had no issues with my TRW top or bottom arms.
Not sure where you're based but a few on here have had theirs done, including me - my VAG specialist in Birmingham did a great job both sourcing and fitting all arms, ends and anti roll bar for the two fronts on my D3.
Old 13th April 2018, 04:04 PM
Lemforder and TRW are the same companay (ZF) do you think they are made on the same line? I bought TRW from mister-auto for about £47 each. They had VW/AUDI logos cast into the aluminium but lasered off.
Old 13th April 2018, 04:20 PM
kele kele is offline
VAG CAR in Cannock did all mine. Apart from myself, they are the only people I trust to work on my cars...
They fitted Lemforder on mine.
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment
2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot
2022 Mercedes EQC 400
Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS
2008 A8 3.0 Tdi sport, B&O
Old 13th April 2018, 11:46 PM
H-M3 H-M3 is offline
www.buycarparts.co.uk
I have bought my complete brakes from them. Spot on delivery and price is very good. They do most brands and if you sign up they have discounts most times.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 14th April 2018, 09:20 PM
Johnmed's Avatar
Johnmed Johnmed is offline
This is the next ‘to do’ on my list. Mine are past their best. How difficult is it to DIY? If it’s a bugger I’ll let my mechanic friend do the honours. I’ve watched 3dogs1monkey replace his on youTube. Does the alignment get thrown out by replacing the arms? Sure I read that it does.
These are mine from today:
ID:	18441   Click image for larger version
ID:	18442   Click image for larger version
ID:	18443   Click image for larger version
2007 Mini Cooper S R56
Old 16th April 2018, 12:24 PM
jamoca's Avatar
The top arms can be a complete bugger to get out, there is a special tool some use (do a search on here and you should find) or you need to remove the shock to replace them.
Changing the arms can throw out the alignment if your bushes have failed for some time - when I did mine I also changed the track rod ends, so the steering geometry was wildly out after, and needed a full wheel alignment job.
Old 16th April 2018, 12:25 PM
Johnmed's Avatar
Cheers mate. Will search
Old 16th April 2018, 05:17 PM
Just a quick question before I buy TRW arms from Mister-Auto.
The part numbers are referenced to manufacturers part numbers, which is great but they are different. Audi own parts quote ends in a F but TRW are saying Audi are B to E.
Are they the same? Please see images.
ID:	18477   Click image for larger version
Old 16th April 2018, 08:16 PM
http://www.realoem.me/Audi/RDW/A8/20...R/4/407/407001
Change the URL where it says 2006 to your model year.
Then look at items 13 and 14 and match the PR code in the right column with two of those on your wheel-well sticker.
There is probably a difference for sports/not sports, but most aftermarket ones seem to be universal/interchangeable anyway.
