Old 28th May 2018, 11:26 AM
homer simpson's Avatar
Default S8 Ingiter
Hi all. My N/S xenon does not work so I decided to change the bulb - nothing. I managed to put it back together but it was very difficult, the igniter just about turned right into the closed position.
So today I decided to swap over the igniters to eliminate them as the fault. I took the O/S off but I cannot get either of them back on! Is there a knack to putting them back on? I have lined it up, pushed in as far as it goes and it seems flush but it will not turn to lock into place.I have tried to make sure the metal locking spring clip is out of the way. Help!
Old 28th May 2018, 02:41 PM
OK I sussed the bulbs out but this is the error for the N/S headlamp if anyone can help
Code:
Address 09: Cent. Elect.       Labels: 4E0-910-279.lbl
Control Module Part Number: 4E0 910 279 S    HW: 4E0 907 279 S
  Component and/or Version: ILM Fahrer      H16 0240
           Software Coding: 0133121
            Work Shop Code: WSC 02313 785 00200
           Additional Info: 4E2910113C  Wischer WWS D3  H60 0440   8K0910557   REGENLICHTSENSORH04 0003
                      VCID: 387EA3A74B1C8E84E0-806C
Fault Codes have been Erased
1 Fault Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 193
                    Mileage: 148690 km
                    Time Indication: 0
                    Date: 2018.05.28
                    Time: 14:29:38
Old 11th June 2018, 11:01 AM
So I finally found the culprit - the ballast. Such a pain as two of the bolts are accessible but the third is not so bumper off and lights out. Swapped them over and the n/s worked but o/s didn't. New ballast ordered, should be here in a few days.
